Question about Bates Power Arm Extra Heavy Duty Stapler 224XHD Staples 240 Sheets
Where to buy staples for Bates 224XHD stapler
When on the stapling process even when it's pushed down the staple wire is not cut.
Probably too late but, here is what you need to repair this expensive stappler instead of buying a new one:
https://www.stapleheadquarters.com/ItemForm.aspx?Item=DUAX29
May 16, 2016 | Rapid DUAX Heavy Duty Stapler 2-170 Sheet...
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
The spring that loads the staples for stapling broke in half where can I buy a new or used one
  1. Panasonic AS-300NN-A Panasonic Commercial Electric ...
    electricandbatteryofficestaplers.julietshop.tk/panasonic-as-300nn-a-panas...Mar 19, 2015 - Commercial-grade electric stapler with 25-sheet capacity features jam-free operation, auto-reverse, adjustable stapling position and LED status ...
Jul 11, 2015 | Panasonic As 300NN A Commercial Grade...
Where do I get staples for a B&D stapler? #9700
There are several brands of staples that will fit your stapler and the price will vary according to the depth of staple you are looking to buy. Arrow brand staples are the most common. All the ones I saw that fit the 9700 are Wide Crown Swingline Heavy Duty
Arrow 606 Wide Crown Swingline Heavy Duty 3 8 Inch Staples 1 000 Pack
Jan 06, 2015 | Staples Tools & Hardware - Others
How do you fix staple jam?
You may have to open up the stapler to expose the loading area then look for staples (or staple fragments) jamming the nose. It may be necessary to resort to pliers to remove the bits.
Aug 09, 2014 | Bates Power Arm Extra Heavy Duty Stapler...
How do you load staples in a Bates gbc 3220st puncher/stapler?
On the right side of the machine are two levers, the one towards the rear is a release button. It releases the "magazine" that holds the staples. Turn it and the magazine will slide out, then put your standard staples in and close. It took a little manipulation of the lever before it released on mine, and I expected the magazine to pop out as if spring loaded and it did not. Try gently pulling on the magazine whiole turining the lever, and it should work!
Feb 15, 2011 | Office Equipment & Supplies
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Bates Power Arm Extra Heavy Duty Stapler 224XHD Staples 240 Sheets Logo
29 people viewed this question
Top Bates Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Bates Office Equipment and Supply Expert? Answer questions, earn points and help others
