Question about Sebo Vacuums
Why won't my Sebo Felix premium brush head won't turn? Vacuum works otherwise, but the power head won't work.
2 Suggested Answers
  • 389 Answers
SOURCE: Sebo Felix Premium Vacuum cleaner brush will not
Just the other day we had a customer bring a Felix in to our repair shop with the same problem. Although she'd had the Felix for several years, she'd never realized that one of the buttons on the base is a foot-operated switch (the left hand one as you see it from behind the machine). Hers had been "on" from day one, and never been switched off... until she'd obviously inadvertently pressed it without noticing and switched it off. Then she thought something had broken.
It may be as simple as that. So, does the green light come on when you operate the foot switch? If it does, and the brush doesn't spin, you have most likely got a problem with the motor (or possibly the circuit board) in the base. If the green light does not come on, there is most likely a poor (or broken) electrical connection where the bag compartment plugs in to the base.
I'll gladly try to be more help if you want to post more details.
Posted on Jul 11, 2010
The beater bar in my vacuum does not go around and there is no suction in the power head?
Turn up side down- check if belt is intact- I would remove belt ant look for an obstruction. Not familiar with this vac but some motors have replaceable bruches on the motor. Try running and feeling for suction. The motor should sound strong when running. Remove beater brush and check for freedom of movement.
Jul 28, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Hi, I have a Sebo premier and the brush wont work or the green light come on. Can anyone tell me if you should get 240v on the connector from the main vacuum body to the brush head? I have tested this and...
I understand 240v to be 240 volts. of electricity- no vacuum should have 240v. that amount is used on elect. stoves, air conditions,welding machines and large electic appliances. Check the belt drive and the manual for the green light operation- I still don't understand the 240v deal.
Jan 06, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Brush not working on sebo felix
I had the same problem. Make sure nothing is clogging the airway, then bring the handle down as if to clean but dont turn it on. Press the 'light' button in and then turn it on. Hopefully that should do it.
Jan 16, 2013 | Sebo Felix Classic Bagged Upright Vacuum
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
My hoover brush will not turn
It has a belt that may be broken or jammed that turns the brush.
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
Sebo Felix Premium Vacuum cleaner brush will not spin. Not the belt, already checked.
Jul 07, 2010 | Sebo Felix Classic Bagged Upright Vacuum
Vacuums Logo
651 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
