Question about Kenwood KRF-V4060D Receiver
Kenwood krf-v4060d tv connect - Kenwood KRF-V4060D Receiver
3 Suggested Answers
  • 4234 Answers
SOURCE: my kenwood krf-v4060d reciever on/off switch is faulty.
The problem is not likely to be the switch itself. The unit is rpobably going into "protect" mode because of a problem internally. Try removing all the cables and try to turn on the unit. If the behavior remains the same, the output section requires repair. The most common failure is the output transistors. Expect a parts cost in the $40-$60 range.
Dan
Posted on Dec 09, 2009
caroldon
  • 17130 Answers
SOURCE: kenwood krf-v4060d receiver display problem,
it is possible that the voltage to the filament of the display is absent. This is normally a 3.6 volt AC which comes from the transformer and it can be lost a the connectors or the circuit board. It will be best to use a multimeter to trace the voltage to the display unit. check the voltage to the display driver IC, check the negative grid voltage to the display , if there is an open resisitor of the feed to the display voltage to the IC. Finally check the continuity of the filament of the display unit.
The driver IC is also a suspect , sumulate heat and see if the fault comes up easily which can confirm the case.
Posted on Sep 05, 2011
Connecting ps3 receiver
buy a optical cable and connect between PS to the amplifier or take the optical out from the TCL to the amplifier and select optical in,
Oct 19, 2013 | Kenwood Audio Players & Recorders
How do I hook up a pioneer dynamic expander ex9000 to a kenwood KRF-V7030D receiver?
• Pioneer EX9000 out to Kenwood V7030D play In
• Pioneer EX9000 in to Kenwood V7030D rec Out
• instruction on page 8 of the manual
PDF] KRF-V7030D KRF-V6030D KRF-V5030D KRF-V4530D
Jul 31, 2012 | Audio Players & Recorders
I NEED A manual for a krf v5200d
  • Hope this helps.
Nov 02, 2011 | Kenwood KRF-V5060D Receiver
Kenwood krf-v4060d receiver display problem, its work for some time but after that no display, sound work fine but not able to see any display on receiver
Sep 05, 2011 | Kenwood KRF-V4060D Receiver
Hi, I have a KRF-4060D receiver and my problem is, that however the receiver is set to auto detecting, when I start a dts movie, the receiver does not recognize it as a a dts signal. could you please...
What DOES it detect instead - analog or Dolby Digital? If the former, the digital bitstream is not being seen at all - check the digital audio-bearing cabling.
If the latter ---
As dangerously loud undecoded digital bitstream [hash] "noise will be produced when a DTS source is played by selecting the analog input", the DTS soundtrack is not necessarily the default for a movie soundtrack and may need to be manually selected under the movie's own Audio Setup menus.
Jul 11, 2011 | Kenwood KRF-V4060D Receiver
The spindle connecting the volume control knob to the control itself has broken. Does the whole assembly need to be replaced? I don't have the old spindle.
Do you mean the spindle on the back of the round knob? If this is the case then you simply need a new knob from the manufacures as the bit that fits over the pin coming out of the machine is a one peice moulded item. If you are very nice to customer services at Kenwood, they may send you one for free. Next time be a wee bit more careful not to knock the control knob as it is quite delicate.
IF on the other hand it is the volume spindle couming out of the unit, then yes this is a whole item replacement. This will need to be repaired by either a accredited Kenwood repair agent or a competent repair shop depending on whether this item is still under gaurantee or not.
Mar 15, 2011 | Kenwood KRF-V4060D Receiver
How do you connect a tv to my kenwood krf-v555od surround receiver
there are two ways using rca cables and using fibre optixs it depends what sort of audio out you have on your tv it will either have rca or digital choose witch one to use and go from there
Jun 19, 2010 | Televison & Video
Need a new remote control KRF-V4060D
You can order a replacement remote on the link below.
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KRF-V4060D+&uuid=12725540403730
Good Luck and please rate 4 thumbs up.for the free answer.
Apr 29, 2010 | Kenwood KRF-V4060D Receiver
My kenwood krf-v4060d reciever on/off switch is faulty, it stays switched on for a few seconds and then switchs its self off.can i get a replacement ? i have had not much luck here,any suggestions !
Dan
Dec 09, 2009 | Kenwood Audio Players & Recorders
Kenwood KRF-V4060D Receiver Logo
18 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
