Question about Peavey Music
Pv20 right main channel no output. some channel strips no output also.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
Are you talking about a PV20USB???
are the faders nasty, how old is the unit??
Posted on Sep 20, 2014
Just bought the mackie 1604 vlz3 mixer and cant figure out how to get sound to the main speakers, the speakers and amps are connected correctly
Simplest is to use the LR button at the bottom of the channel strips you want to send to the main mix. Make sure you set the gain for each channel in use so that the clip light just occasionally blinked then back off a fraction.
If you want to use sub channels assign the strip to the appropriate one 1/2 or 3/4 and the assign the sub to the main mix and bring the subs up.
May 21, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
How to connect s1100 akai sampler to a mixing board music amplier how to connect the jack plug into the right connections
You would come out of the S1100 l/r output jacks into your mixer line input jacks on 2 channels, one panned left, one panned right. Be sure to adjust the input pad on each channel to where you're getting a hot enough signal and that the channels you're inputing to are routed to the mixer's main outputs.
Dec 13, 2014 | Akai Music
Driver for Peavey PV20
what operating system are you using?
Feb 05, 2014 | Peavey Pv 20 USB 20 Channel Mixing Board...
Setting up pv20 usb
http://www.peavey.com/products/index.cfm/item/699/116338/PV%26nbsp%3B20%26nbsp%3BUSB
Look under "Downloads" tab at bottom for owners manual info. In a nutshell...mic to mixer channel #1, mixer connected to power amplifier, amplifier connected to speakers. Start with zero volumes on all equipment, bring up amps 1st (1/2 volume) and then adjust mixer until sound is heard from the microphone.
Oct 31, 2012 | Peavey Music
No sound
There can be any number of reasons for this problem - solve it diagnostically by starting with something that you know is working and work through systematically to the other end.
  1. Test a microphone on a separate amp to make sure it works okay. Check amp and speakers working. Check that all output cables from mixer to amp are working by testing separately.
  2. Plug microphone into a channel on mixer. Also plug in headphones and turn headphone volume control up.
  3. Make sure input sensitivity knob is turned up a bit (say half way) and main output faders (yellow) are up.
  4. Check that channel is turned on (little button just above the channel fader- needs to be pressed down)
  5. press pfl (pre-fade listen) button (next to button to switch channel on)- do you get any sound on main output or headphones or any indicator lights on mixer to show signal is getting that far (eitehr the individual channel metering lights or the main ones in the central section)?
  6. turn off pfl - make sure channel fader (slider) is up - normal position is ) - about 3/4 of way up. Check lights again on individual channel and main output section - any signs?
  7. Is the sub mix button for the channel pressed down - in which case you will need to bring sub mix (red) output faders up as well as main faders.
  8. If you have got signs of signal on the individual channel but not main see if the channel has been routed somewhere odd (like a subgroup of channels).
  9. Plug a working amp and speakers into one of the auxiliary outputs and use the relevant auxiliary send knob (on each channel just above the faders and pfl switches) to pan some signal to that auxiliary out - do you get anything? There is also a headphone socket for listening to the auxiliary channels (with a selector switch /knob to determine which one - make sure it is in the right position) try listening to the auxiliary output with headphones - anything? If yes the problem lies in the main output section.
  10. Check that there is not a jack plug in the insert socket (to route signal through an external effects unit) without a matching return jack being plugged in - if appropriate is relevant effects unit switched on and correctly set up - if unsure remove the insert plug to take it out of the system.
  11. Make sure any mute buttons are not switched in on main outputs.
You can download a full user manual here http://www.allen-heath.com/gl/gl2400
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
I would like to know I have 2 subwoofer with amp how can I connect it the best way thank you
first, you will need a passive crossover, i do not believe that the mono out of the mixer has a crossover., if the amp does not have a crossover. you could use the "mono" output, and split the signal, with an adapter, to both channels of the crossover, then run both of the low outs to the 2 channels of the amp. or, you could hook the crossover to the main laft and right outputs of the board. send the 2 low outs, left and right, to the subs' amp, and send the two high outs, left and right, to the main speakers' amp.
Nov 24, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hi I have a mackie sr series 24.4.2.b bus miximg console in for repair,most of it is working except that the right channel output is misssing on on sub outputs 1 and 5 and 3 and 7,i do not think its...
Remember that the subs are each MONO outputs. They do not have stereo outs. They can be used as pairs like 1-2 for stereo and those should PAN with the pan control at each channel assigned to a sub.
For mono's, the left channel is the one used.
Refer to the signal flow diagram for the Mackie mixers to analyze this. It probably is on page 28 of your manual.
For the subs, you can pan AT THE CHANNELS ASSIGNED between for instance sub1 and sub2. Note these work together as odds and evens.
Jul 14, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Computer->M-Audio-FastTrackPro USB->trs outputs 1/2->linein 11-12 of mackie 1202-vlz3. How can i get stereo sound out of the mackie?
Use TRS to TRS balanced cables from the M Audio to the line in 11 and 12.
Set the pan controls for the 11 and 12 to opposite directions to split the stereo to left and right main outputs. (otherwise both main outs mix the left and right and you get mono result.
Feb 05, 2010 | Mackie 1202vlz3 12 Channel Mixer
I have a behringer pmp3000 how do i select the setting to allow me to have mains on one side of the out and monitor on the other? I know the selector switch must be in a certain position, but which one,...
You want the mon1/mono setting. The center position of the slide switch to use each half of the power amp seperately. Then fiddle with the controls BOTH in the strips and the faders to get desired result.
May 15, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
