Question about Kenmore Ovens
F90 code is showing on my 79090939603 kenmore stove
Saying door is locked when the door is not locked.
    Champion:
  • Kenmore Expert
  • 320 Answers
Posted on Feb 02, 2015
SOURCE: self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Posted on Mar 07, 2009
localwonder
  • 6784 Answers
SOURCE: Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
Posted on May 22, 2009
localwonder
  • 6784 Answers
SOURCE: error code f90, lock motor continuously runs. How
HI, this is a door lock switch failuer code. you will need to check the door lock mechanism for faults. check the wiring harness for lose fit and corrosion at the contact point. if the wires are in good condition and, the door lock mech is functional, replace the oven control board.
Posted on Jul 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: f90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Posted on Oct 01, 2010
bestdarngood
  • 3037 Answers
SOURCE: I Have A self cleaning
There is a bad connection on the door lock to the sensor that detects whether the door is closed. Usually this means the door lock is broken, repairclinic.com will have a replacement if you find that this is the case. Let me know what you find.
Benjamin
Posted on Nov 04, 2010
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
Keeps beeping and saying f90
I found this, hope it helps:
F90-Maximum oven door unlock time exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch. 2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary. 3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam. 4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, repl;ace Lock Motor Assembly. 5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly. 6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch. 7. If all situations above do not solve probem, replace EOC.
Oct 25, 2012 | Ovens
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
Frigidaire oven error code
Accessories For Audi
Jun 12, 2012 | Ovens
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
Jul 19, 2011 | Kenmore Ovens
Error code f90 double oven
Hello, Thank You for using FixYa. I will be helping you today. F90 is a failed door lock check the lock switch and check the lock motor if its good replace control.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Frigidaire Ovens
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
unplug the range.
wait 1 minute.
wait 2 minutes.
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Error code f90, lock motor continuously runs. How
Jul 19, 2009 | Ovens
F90 code flashing and i cant reset it
unplug the range.
wait 1 minute.
wait 2 minutes.
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
May 22, 2009 | Stoves Ovens
Ovens Logo
57 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
