Question about Whirlwind FH-778 Air Conditioner
I put on the AC and only cool air is coming out of it not cold
  • luwayne1 Jun 18, 2009
    buy a new one
  • 83 Answers
If the compressore hasn't kicked in yet there would be no cold air, if it did and still no cold air, you should have it checked to see if you need refrigerant recharging. Also check the thermostat setting for your desired temperature.
I hope this help.
Posted on Jun 18, 2009
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
AC not blowing cold air
have ac checked and refilled
Jul 04, 2010 | 1997 Mercury Mountaineer
Can't seem to get the compressor to come on. When
hi how are you...you say your outdoor unit is not working...is thermostst set in heat or cool when this is happening....if the compressor is running,go outside put your hand on the big copper line,if it is hot,your in heat mode,if it is cold your in cool mode..is it heatpump or ac only...if ac only ,you have a sequencer stuck ,or contactor closed keeping heat on...please chek items first...michael doctor airr appl.repair 843-384-8474...if need help call,ill help talk you diagnosis of problem...
Mar 27, 2010 | Carrier 38CKC060 Air Conditioner
AC doesn't blow cold air, but refrigerant levels
The low side pressure seems ok the high side would help,Is your compressor cycling and is the air coming out even slightly cool?slight over charge cold effect cooling ability.I wish I could be more help. I will have to think about this one.maybe you could make sure your temp.door is actually in the commanded cold position.
Aug 25, 2009 | 2003 Pontiac Vibe
Cool but not cold air from my ac system
It sounds simple enough that you need to recharge your A/C unit. They can stop functioning properly after winter's end especially if they were not used. You should be able to get a recharge kit from your local auto parts store. Your Suburban should use the newer R142a refrigerant.
Jun 09, 2009 | 2003 Chevrolet Suburban 1500
Heating & Cooling Logo
76 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
