Question about Utilitech Plumbing
Utilitech sump pump model 090epp304 will not run
Sump pump motor only hums and will not start
SOURCE: Loud Whining/Humming noise while washing
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Posted on Mar 22, 2008
  • 104 Answers
SOURCE: ive got a shallow jet
Just curious, why do yo9ur run water from a tank to a pit?
Where is the pressure switch located? At the pump I presume? What will increase the pressure? If you are pumping to an open pit, you will never build up any pressure? What is supposed to restrict the pump to create pressure?
You need a restriction to create pressure to turn off the pump. Is there a float valve like in your toilet in the pit? If not this would be required
Good Luck
Posted on Mar 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: sump pump won't stop running
Notting your statement that water is running in like someone turned on a faucett... Your sump pump is simply doling it's job. As the water rises it triggers the float switch / sensor and activates the pump. The pump has enough capacity to empty the catch basin to the point the float / sensor switch shut the unit off. The pump is thermally protected and will stop if there really is a problem. You home electrical circuit more than likely has either circuit breakers or fuses. From what I am reading none of those have tripped or blown. Once again the sump pump is simply working normally based out your description of the the amount of water coming in. Also not that if it did not run you would be faced with a flooding situation. Relax and enjoy your day :)
Posted on Jan 05, 2010
radar001
  • 1051 Answers
SOURCE: sump pump hums and then kicks breaker. Will not
Pump motor is jammed causing overload and resulting breaker trip. Try to turn the pump shaft by hand, it should be very easy to turn. If there's any resistance check for blockage.
Posted on Apr 09, 2010
packrat1948
  • 528 Answers
SOURCE: My Flotec Model FPSC3200H-01 1/2hp
Well I know it a dirty job but someone has to did. Unhook the pump from the plumbing and take the pump out so you can see what fell into the sump pit and is lodged in the impellers.
If you have it out already turn the impiller backwords and see if that frees it up.
Posted on Feb 05, 2011
I just purchased a utlitech 1/2 hp convertible jet pump. When I turn it on it just hums.
I
The hum is the sound created by a motor when it cannot start either because the load is excessive and it cannot do the job or if the start capacitor is bogus.
If cap is good, motor should start immediately upon turn on. Measure cap with cap meter or simply replace it. The capacitance should be the amount indicated on the cap and not more than 10 percent less.
If capacitor is good the pump itself might be frozen. Try running the motor not connected to the pump.
Aug 29, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
Aug 20, 2015 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
Purchased new well pump have electric however the pump will not start
Does the pump hum? Sounds like start capacitor is bad in control box.
Apr 03, 2014 | Utilitech 1-HP 18-GPM 3-Wire 230-Volt...
Utilitech pro submersible pump has good electrical connection but pump won't start
There is a starting capacitor on the motor pump, check this out if faulty then replace it.
Dec 28, 2013 | Utilitech Plumbing
Utilitech sump pump
See if there is power. If so the level switch might be stuck off. If that is OK then the pump motor has probably failed.
Nov 20, 2013 | Plumbing
I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
Nov 02, 2012 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Pump not working
If power is going to pump and float switch is good, motor has fried, time to get a new one.
Oct 07, 2012 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Plumbing Logo
48 people viewed this question
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
