Question about Kitchen Ranges
Frigidaire Gallery series 316233850
I was boiling water on all 4 burners and water seemed to splash out and liquid was on stove top , and everything went dead , breaker is on power to outlet, no power to stove at all ? Is this a simple fuse located in back of unit? Or did I fry all the circuits?
  • 1314 Answers
SOURCE: Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Posted on Jan 19, 2008
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
SOURCE: frigidaire electrolux gallery series
stoveboy,
I know you probably have the problem fixed by now, but I had the same problem with my frigidaire range just the other day. Loud popping sound, range/clock controls do not work. Stovetop still works great.
I took the back off the stove and got to the circuit board. Unplug the connector and the five spade connector wires. Once you do that, remove the 4 screws holding the entire assembly in place. The circuit board(s) are held in the housing with retaining clips on the housing. Use a small screwdriver or similar to pull back on each clip to pry each side of the board out. Once the board(s) are free, look in between the two circuit boards and you will see the problem. The larger, 20 amp relay is the culprit. It blew traces off of both boards making it almost impossible to repair. Without having a schematic to go by, I went ahead and decided to just replace w/ new boards as opposed to trying to solder the traces. I have not checked on prices, but brief web searches didn't return any results. The board part # is SF5301-S7509-N
Posted on Feb 15, 2009
  • 81 Answers
SOURCE: Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Posted on May 07, 2009
SOURCE: Viking stove top gas burners
I have a VGR36 6 burner. All the spark ignitors stopped clicking after a major boilover spill. Liquid got into the spark module compartment and caused a short. The paper wiring diagram under the spark module protective cover was burned from the short. I had a Harper 6542 non-reignition spark module but the replacement part is now a Tytronics PA020041 Spark Module. I bought kit #000511-000 from allvikingparts.com which includes the module, a black jumper wire, a green ground wire and an instruction sheet.
It's not difficult to replace the spark module but the 2 screws holding down the module toward the back of the stove are not visable and accessible. I used a thumbwheel rachet with a long philips screw driver bit (for cordless drills) to remove and replace the screws. The wiring was simple. The 2 power wires need to be wired to the correct polarity on the module, but the remaining 4 ignition wires can be wired to any of the 4 terminals on the new module. All the wires have plug in connectors and no cutting and splicing is necessary, but I had to cut and splice because one wire shorted and the insulation was burned from the major spill on my stove.
Posted on Mar 19, 2010
Our glass top range quit last night. The breaker threw and when reset, it snaps. All 4 burners, lights, etc not working.
any electrician knows that besides a short activating a breaker , items such as leaking insulation , moisture , or control unit problems will trip a breaker
so get in an electrician to test everything
Jul 05, 2017 | Dryers
Why do burners not get hot? After rehooking to electrical power, due to a remodel, the burners don't seem to heat up as hot as they used to. Cant boil water on any of the 4 burners.
Could be not enough voltage on your 220.lines ( one wire lose or a bad breaker. or the wires are hooked up wrung causing it to try to operate on 110 instead of 220
Aug 17, 2014 | Kenmore Electric Smooth Top Stove
My whirlpool electric stove not turning on
Make sure it is plugged in and you have power to your house.If everything is dead check your fusebox for blown fuses if you have circuit breakers reset the breaker for the stove by turning it off then back on. If the burners on the top work,but the oven won't you probably have a burned out bake element .To change this turn off power to the stove and unplug remove 2 or 3 screws holding the bake element and remove the wires to the element by loosing the screws on the terminals note sometimes bake elements plug in in this case just unplug. Reverse process to install. Reapply power and test.
Aug 06, 2014 | Whirlpool Stove / Oven / Range Electric...
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped...
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Apr 30, 2017 | GE JBS55 Electric Kitchen Range
I was boiling a chicken on top in a pan, I heard a pop. The top had cracked! It is about 4 months old.
Probably not much you can do about that. In the future do not boil food on the refrigerator. I doubt the problem will be covered under warranty. Try cooking food on the stove when possible. :-) You may try sealing the crack with silicone.
Nov 07, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
3 of 4 knobs do not compress to turn on gas
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Jun 14, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
Jun 11, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
