Metra CHTO-02 Chrysler Pacifica 04-Up Radio Interface Logo
A
Anonymous Posted on Apr 15, 2014
No sound on the radio on a 2006 chrysler pacifica
1 Related Answer
clifford224
Clifford Beard
  • 1975 Answers
  • Posted on Dec 07, 2012
SOURCE: where is pacifica factory amp located
There are a couple of different systems. There are 2 pictures below that should help..............
2005 Chrysler Pacifica with 3.8 engine. Is there a interior fuse box in it please.
question edited for clarity.
Question moved to model category.
No, it just has the Integrated Power Module in the engine bay.
Chrysler Pacifica (CS; 2004-2008) fuses
Fuse-Box.info https://fuse-box.info > chrysler > chrysler-pacifica-cs-...
In this article, you will find fuse box diagrams of Chrysler Pacifica 2004, 2005, 2006, 2007 and 2008, get information about the location of the fuse panels ...
Chrysler Pacifica (crossover) (2003-2007) fuse box ...
imgVEHICLE.com https://imgvehicle.com > chrysler > fuse-box
An Integrated Power Module is located in the engine compartment near the battery. This center contains maxi fuses, mini fuses and relays. A label that ...
Chrysler Pacifica 2005 Fuse Box/Block Circuit Breaker ...
CarFuseBox https://www.carfusebox.com > chrysler-pacifica-2005-fu...
Apr 6, 2022 - Chrysler Pacifica 2005 Fuse Box/Block Circuit Breaker Diagram ; 2, C51 18LB/BR, Fused Rear Booster Fan Relay Output ; 3, W4 12BR/OR, Front
PCM chrysler pacifica 2006
If I remember correctly, it should be behind the inner wheel liner on the drivers side behind the bumper. Just pull the drivers wheel and the liner is easily accessible.
1helpful
2answers
Radio wont turn on.
Check fuse first. Then pull the radio and check power. If you have power at the plug, replace the radio. If the radio comes on(or still has a clock) and no sound, look for an amp fuse or replace the amp.
I can't see the radio station on my Chrysler Pacifica 2006!!!
I am afraid it will cost less to replace then repair, If it still works you may be able to use the program buttons .
An alarm sounds when i get my 2006 chrysler pacifica limited up to 70mph any one have this problem ?
look in your owners manual it might have a optional speed alarm that can be set to different speeds
Radio sound just quit on 2006 chrysler pacifica. Also, there is no Serius Radio channels.
Sounds like your stock amp may have given out (aka defective). Did you spill any drinks in the car recently? Also, you can check the serious radio box. It should be located under the lift panel at the back of the vehicle. It's a little black box that says "Sirius" Hope this helps.
How do you unlock the radio on a 2006 chrysler pacifica
Your vehicle is equipped with an anti-theft radio. If you do not have the code to unlock it, I recommend you take your car to a dealer to obtain the specific code for your car. This code is given with your vehicle's manual upon purchase.
8helpful
2006 Chrysler Pacifica serpentine belt routing
here are a couple diagrams...
If you need anything else, let me know.
Top Metra Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
