Question about Hamilton Beach Beach 87108 Microwave Oven
Fuses how do i access the fuses
No power at microwave. Plug fine. Query internal fuse? Location of fuse?
The fuse is inside. The outer cabinet has to be removed to gain access.
Dec 08, 2014 | Microwave Ovens
How to change fuse
If it is an over the range unit then the front control panel will come off and you can gain access to the fuse. A wall unit panel will open up and again gain access. If it is a counter top unit. the case will have to removed and you will gain access to the fuses. Now what tripped the fuse. It could be a bad door switch. a shorted high voltage capacitor or it may not be a fuse at all it could be the flame sensor tripped or the magnetron sensor. Some over the range units have a sensor that will shut it down if the stove gets too hot. look for burned connectors. be very careful of the high voltage circuit and make sure the power is off.
Oct 12, 2014 | Microwave Ovens
How do I change the fuse?
On most GE/Hotpoint models, the control panel assembly will either tip down, or pivot sideways for access to the components behind it. Screws holding the top air deflector might have to be removed in order to gain access to the control panel mounting screws. I recently junked-out a similar model. The main fuse was near where the power cord enters the cabinet on top. Avoid contact with any of the high voltage components.
May 07, 2014 | Hotpoint RVM1325WW Microwave Oven
I'm getting conflicting directions on how to replace a fuse in my JVM1440...Is there more than one way to access the fuse. One said to take the MW off the wall, remove the case, then have access to...
Hello there and thank you for choosing fixya
Actually the unit does in deed have to be removed from the wall because the outer shell does need to come off there is a series of screws on the edge of the back that need to come off and there are some on the sides then the outer cover will slide to the back about 1 to 2 inches then lift off and the fuse is on the control board towards the front right as you are looking at it from the front of the microwave ok
Hope this helps best regards mike
May 11, 2011 | GE JVM1440 Microwave Oven
I have a GE JE1660 Profile Countertop microwave oven and it just quit. No warning, no lights, no response to any button pushed. Fix or replace?"
there is a 20 amp fuse inside the unit ,but requires to gain access.. may luck out and it just blew the fuse... normally they are behind the control panel unplug unit and take screws out to gain access hopefully that will fix you up ...if the fuse is good i would suspect you have a failed control board on the unit.... good luck
Feb 11, 2011 | Microwave Ovens
It won't power on. Would like to know how to replace fuse?
To access the fuse,remove the outer cabinet shell.
Follow the incoming power wire to the fuse block.
If you have any light or display at all working the fuse is OK.
Sep 28, 2010 | GE JE635 Microwave Oven
Trying to locate the fuse in an Admiral Microwave ksa - 8533A , power went out I was informed the fuse went not able to find it
you will need to remove the outer wrap on the oven to access this fuse,it will be in a clip and be white colored with silver contact ends it is a special ceramic fuse hardware stores carry them in either 15 or 20 amp ratings use only this type fuse
Nov 18, 2009 | Microwave Ovens
How can I find my fuse on my Sharp Carousel R-1471A
your fuse holder appears to be behind the control panel area. you may be able to just remove the grill above the door and control panel to access the screw that holds the control panel in place, then swing that down and see the fuse and holder.
you may however need to lower the unit from its mounting place to remove the outer cover to access this fuse..
hope this helps,
best of luck,
ttfn
Oct 30, 2009 | Sharp Microwave Ovens
Changing a fuse in a Galanz 700W Microwave Oven
A microwave casing can be removed and almost full access to the electronics with about 6 screws.... make sure to unplug it from the wall first.
please vote on your answers to keep the site free.
Sep 04, 2017 | Microwave Ovens
Hamilton Beach Beach 87108 Microwave Oven Logo
53 people viewed this question
Top Hamilton Beach Microwave Ovens Experts
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
