Question about Health & Beauty
Wiring for 959-j3 freedom scooter - Health & Beauty
2 Suggested Answers
HoverTech
  • 232 Answers
SOURCE: We need wiring diagram for
That information is usually proprietary and legally protected by the manufacturer. I highly doubt that you will be able to get the diagram for a power chair/scooter that is currently in production. If it is a discontinued model, you may be able to get it directly from the manufacturer, but the odds are not good.
Posted on Oct 27, 2010
What does it mean when 1green light stays on when i charge my freedom 959-j3 scooter
The charger may not be operating. If the batteries fall below 20 volts, the charger will not bring them up. You need to take the batteries out and use an automotive charger to charge them individually. It may take several days on the charger for each battery to get them back up to the point where the scooter charger will continue charging.
Sep 16, 2016 | Health & Beauty
How do I fold and store the freedom scooter
Watch the cute video on the scooter.
At the end it shows how to do it. Freedom Mobility Scooter
Jun 07, 2016 | Health & Beauty
Fan not working
Hi, Anonymous for more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://absolutelyscooters.net/service-manuals.html
CF250 Water cooled parts
http://www.cfmoto.cn/download/?cateId=1&Id=16
CF Moto 250 Freedom Scooter 2007
CF Moto Freedom Fashion 250 Scooter Review
Jan 19, 2014 | 2007 C_F Moto 250 Freedom Scooter
Have a pro rider freedom sometimes it will switch on and drive other times it turns on an bleeps and wont move
hi,okay the bleeps , bleeps and pause or continuous bleeps ?
Has the scooter been serviced recentrly ?
Regards
Rob
www.gewizrepairs.co.uk
Jan 10, 2014 | Electric Mobility Power Electric Scooter...
I looked at a 05 freedom 250 scooter today that is for sale. The scooter has less then 500 miles on it. The owner states that he just paid $400.00 to have the carb worked on and fuel pump replaced. The...
Hi, Rmupdyke the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and free downloads that you need please visit the websites below. Good luck and have a nice day.
Sep 07, 2011 | 2007 C_F Moto 250 Freedom Scooter
We need wiring diagram for a Freedom Scooter.
Oct 20, 2010 | Health & Beauty
I need a wiring diagram for a freedom scooter. Its 36dc volts.
That scooter brand is also known under the name
"X-treme" and the one your looking for is the "XG-470" I believe. Here is a link for an owners manuel to it. Hope it helps out.
http://manuals.monsterscooterparts.com/recreational/X-Treme/owners-manual-xtreme-xg-470.pdf
Jan 11, 2009 | Electronics - Others
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
