Question about Vacuums
I have an Innotek ce0682 dog collar. The collar has been charged and is flashing a green light. I changed the batteries in the hand held controller and pressed the id button But I get no tone sound and don't think it shocks the dog at all. What else should I do?
  • 363 Answers
SOURCE: My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Posted on Jul 27, 2009
pappapumpdaf
  • 635 Answers
SOURCE: I think the battery is not holding its charge
You have dead nimh (nickle metal hydride) batteries2_bing.gif.
You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
Posted on Mar 11, 2010
  • 273 Answers
SOURCE: looking for users manual for anti-bark dog collar
Innotek has a manuals download site here
A citrus spray model manual is here
Posted on Jul 07, 2010
SOURCE: My hand held Dyson vacuum will not charge. Every
My same symptoms are - after starting charge, Red light is on, then second light turns On. Then for a long time nothing happens. And later I have all three LED flashing.
I replaced battery and nothing changed.
Imeasured Power Supply voltage and found it 24.2v instead 28v as it stated on the label.
I opened it up and found that the three-lid chip marked 431 is faulty.
431 is a voltage shunt, which sets and controls output voltage.
You can use AIC431CUS or TL432 (TL431 has different pinout).
I replaced mine and volatge back to 28.25v and charger is now working as it should.
You can also use any TO-92 431 chip - there is enough room for it.
Posted on Jul 30, 2010
  • 5370 Answers
SOURCE: the little green light is
The power is not the problem, but motor is problem.Thats why the green light still comes on, but motor is not coming on.The motor is got short and needs to be replaced.This motor has a tendency, to get overheat and machine automatically cuts off and again starts after motor cools down.But slowly slowly, the coils in the motor gets burned out and motor itself gets weak and at last stops working.-------In your case the motor made odd whirring sound and at last stopped working.-------- But still check the wires passing from motor to the main control board.May be any of the wire got overheated and burned out and this caused the problem.But most probably its faulty motor, that needs to be replaced.----------- This will help.Thanks.Helpmech.
Posted on Sep 04, 2011
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Hello, what is the significance of the lights when charging? The red and the two green lights are flashing when charging. After the time charge (1 night), the Dyson DC 16 does not function, the battery...
yes the reason the green and red light were flashing the way they are is because its a warning to you that the battery is either no longer good or there is problems with your wireing. Also those vaccumes were designed to not charge when there to cold or to hot as a saftey issue.
Aug 06, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Dropped off countertop. Will not work now. I have bottom Red and two green lights flashing ??? I have had the battery on the charger< and had it tested. The battery is full charged but still will...
There is a small magnet on the pre- filter that triggers a switch. Pull it apart and you'll see the magnet but the switch is behind plastic.. Make sure it is seated well against the motor unit.
Jan 13, 2011 | Dyson DC16 Root 6 Bagless Handheld...
We ran our Platinum Series 18 volt hand vac until it stopped -- charged the battery overnight but it did not charge. is there a problem with the battery charger or what could cause this?
Most problems with what you have stated have to do with bad contacts between the hand held unit and the battery charger. With the charger unplugged, make sure the contacts on both the charger and hand held unit are clean and not bent. Check to see what the "Light Indicator" should be when charging and reinsert the unit into the charger. If the light does not show what it is supposed to show, move the hand held unit around a bit to see if you can make the connection better.
If this does not do the job, depending on the age of the unit, might be time to replace the battery.
Oct 06, 2010 | Black & Decker CHV1500 Bagless Handheld...
My hand held Dyson vacuum will not charge. Every time I attempt to us it I get 3 charge light on the side flash?
May 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
