Question about LG LT0810C Air Conditioner
Same problem Looking for help.
  • 1 more comment
  • tcduongxx Jun 18, 2009
    I plug an LG 120V max window AC unit into a 220V power source and now the AC does not work.
    Is there anything I can do to fix this?
  • tcduongxx Jun 19, 2009
    Is there a fuse in the LG AC unit?
  • tcduongxx Jun 23, 2009
    The plug have an over current on it and push it and it seem to reset properly. I plug it into the 120V and the indicator light on the plug shown to be on. The AC digital screen is not on and I push the on button it does not start. Can it something that is blown on the system circuit board?
    President:
  • 2,187 Answers
Like most household appliances all does not use the 110 or 220 volt. The output from your socket is usually converted to DC. Electrical components such us the thermostat are running on DC at a lower voltage. LG released DC motors for Airconditioning, I am not sure with yours since I could not find the specs but surely your unit has internal components using DC.
To convert the power to a usable one, internally you should have a power supply inside. If you trace the power cord (while unplugged) it would lead to it. Some would have a fuse inside while others have none. If yours has one, just replace it or have it reset but if there are none you will have to replace it.
Posted on Jun 23, 2009
  • 10,515 Answers
If the fan does not operate, check the power supplu to the unit. Check to see if the breaker or fuse for the unit is tripped. If the breaker/fuse is tripped, check to make sure that it is the proper size circuit for the unit you have. On some units, there is a current interruptor on the power cord to the unit. Check to see if it is tripped by pushing the reset button. If the circuit is the proper size, then you can go ahead and reset the breaker/fuse. If it trips again, then you require further troubleshooting. Shut the power off and check all of the wiring in the unit to make sure that none of the connections is loose or damaged.
If the fan does not operate but the fuse/breaker is not tripped, you should check the run capactitos for the fan and compressor. If the capacitors are good but the fan motor does not operate, you can check the fan switch and the fan motor. Ensure that the fan blades spin freely.
If the fan motor operates but the compressor does not start, you should feel the compressor with your hand. If it is very hot, then you should allow it to cool. Then, you can take resistance measurements to make sure the compressor motor is good.
Then, you should attempt to start the unit in the cooling mode. As you do so, listen for a clicking sound which is an indication that it is attempting to start. If the compressor starts but does not cool properly, the unit may be low on refrigerant.
If the compressor attempts to start but shuts off very quickly, the compressor could be bad. Generally, if the compressor is bad on a window air conditioner, it is cheaper to replace the entire unit than to fix it.
Check and let me know if that would solve the issue.
Thanks for using "Fixya".
Posted on Jun 19, 2009
  • LG Master
  • 13,433 Answers
You plugged a 120v machine to 220v ? Its blown, replace the circuits that are blown. would need to inspect to machine as to how much damage has been caused and replace blown, fried parts.
  • Ekse Jun 19, 2009
    or it could have simply just blown a fuse.
    Sergeant:
  • 326 Answers
Can u explain u r problem please so i can provide u proper solution
Posted on Jun 18, 2009
Code for grundig GR0947W1733228
Can you give me a little more information? What code are you looking for? Are you looking for the removal security code? Are you looking for the tuner's activation code? Just which code do you need to help and what is the issue? If you give me a bit more to go on, I can help. Tks.
Jan 14, 2015 | Cars & Trucks
Hack moviestarplanet
please help me to get free VIP star-coins and fame and diamond please help me with that thank you.
Dec 09, 2013 | Jonathan Dimond Android Apps
Hi there, I'm looking for a driver for a Creative EV1938 4CH PCi Sound card. Can anybody help? The creative site does not have the driver I'm looking for.
Hi , try this link hope it helps, you can downalod the Drivers there. If it does help you out please give me thumbs up thanks..
Aug 28, 2010 | Creative Labs Ensonic PCI Sound Card
Hi, I am looking for Q7 user manual ? Do you help me ? Thx.
hi, I am looking for Q7 user manual ? Do you help me ?
Jan 20, 2010 | 2008 Audi Q7
Looking for a diagram of how all vacum lines hook
See if this is what you are looking for. I hope that this helped and best wishes.
Jul 30, 2009 | 1995 GMC Safari
Nokia 5310 restriction code?? HELP :(
Buy it on ebay. Most sellers have a "Make an offer"
ad, and will accept immediately about half what their "Buy it now" price. is.
Mar 02, 2009 | Nokia 5310 Cellular Phone
Hi, im looking for drivers to lexmark X3350 in windows me
hi.. if you are looking for driver's for your printer, here is the link for that download.. please let me know if this helped by rating me helpful if possible.. thanks, d
http://www.nodevice.com/driver/X3350/get32599.html
Feb 22, 2008 | Lexmark X3350 All-In-One InkJet Printer
Casio 240cr
ftp://ftp.totalpos.co.nz/Oldmanuals/Casio-240CR.pdf
check out this
this will help
cheers
tim at shropshire-hogroasts
Sep 02, 2007 | Office Equipment & Supplies
Heating & Cooling Logo
74 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
