Question about Sony Cyber-shot DSC-N1 Digital Camera
I have a sony cybershot 7.2 megapixels
I accidentally hit the delete all button and there is no button do undo the action. is there anyway i can get the pictures back because they are very important and i need the pictures.
  • 986 Answers
Sorry to hear that, No you lost them.
Posted on Jun 18, 2009
Where can i find the reset button?
No camera has a reset button. Although there is a microprocessor in it, the program in ROM will not be changed. (EEPROM) and only few camera's get an update.
The switching of or removing the battery will have the same effect as the cold boot of a computer.
If the problem returns after one or both of these actions, something more serious is wrong, not to be solved by any reset. You should contact a Sony certified repair centre for your camera.
Jul 21, 2014 | Sony Cybershot DSC-W180 10.1MP Digital...
Tip
How Do I Reactivate The "Undo" Function In Ms Word?
It is possible to redo, undo and repeat a plethora of actions in Microsoft Excel, PowerPoint, and Word. It is possible to do changes after saving and you can again save after that. It is possible to do it till you are in the undo limits. The Redo and Undo features are helpful in rectifying the mistakes without any hassles. You can also make use of the function for experimenting with a wide array of data mapping and routing decisions. Undo helps in reversing the last performed action whereas Redo is helpful in undoing the last Undo action. The Undo command present in Microsoft Word is helpful in undoing anything you have typed in the Word Document. This is inclusive of deleting and typing text, moving the blocks, formatting of texts. There are primarily two ways in which you can utilize the Undo command. You can do so by pressing the Command+Z button as well as by clicking the Undo command button present on the Quick Access toolbar.
Undoing with Command+Z
Command+Z for Mac is considered to be the keyboard shortcut for the Undo function. This will help in saving the Microsoft word files from unintentional formatting and accidental deletions. The Command+Z is considered to be the shortcut option for the Undo function. For undoing the most recent change, it is recommended to opt for Command+Z option. For undoing a plethora of actions, you need to press the Command+Z in a repeated manner till the action you are willing to do has been undone. You require clicking the arrow present to Undo option on the Quick Access toolbar and choose the design change which you wish to undo. You should undo all the chosen changes in the design. You will gain success in undoing the actions in the similar order of occurrence. For instance, you should be undoing the first recent action for undoing the next most recent activity.
Undo Command Button
An added benefit of the Undo command button is that it helps in sporting the drop down menu which is helpful in reviewing the several things which you have done in the past and that can be undone. However, you are not allowed to pick or choose from the drop-down menu of the Undo command button. It is possible to undo the multiple instances of different things at just one time. The Undo Command functions at times sporadically. Word will issue a warning before it happens. The Undo Command will not work if there is nothing you can do or in case you cannot undo something simply. For instance, it is not possible to undo the saved document.
Redoing, The Undo-Undo Command Present In Word
In case you accidentally undo something which you are not meant to, you should utilize the Redo Command for setting things in a previous way. You will have primarily two choices which include Pressing the Command+y and clicking the Redo command button present on Quick Access Toolbar. When there is nothing left which can be done by the Redo Command, it is capable of changing functions and turning into the Repeat Typing Command. After typing something and pressing the Command+Y and selecting Repeat Typing command button present on the Quick Access Toolbar, Word is able to repeat the few last things which you have typed. In case you required pressing the Backspace key for backing up as well as erasing, the Command+Y is known to repeat from the specific point only. It is possible to redo the different actions in the similar order in which they were undone. For instance, for redoing the next most recent undone function, you require redoing the very recent undone activity.
Repeating The Action
For repeating anything like the paste operation, you need to press F4 or Command+y. If you find that F4 is not working, you may require pressing Fn key, Flock key, and F4 after this. In case you prefer using the mouse, you should be clicking Repeat present on the Quick Access Toolbar.
Undoing Different Changes By Reopening The Document Manually
In case you have accomplished a lot of changes in the Microsoft Word document, using the shortcut or clicking the Undo icon is not going to help you. In such cases, you require reopening the document. You have to close the document and make sure not to save the changes. You should be clicking Don't Save as Microsoft word ensures that the operation is closed. After reopening the document, different changes which are done previously will be gone.
How Do Reactivate The Undo Function In Ms Word
on May 10, 2018 | Microsoft Word Computers & Internet
Sony cybershot 200 dcs w200
5 megapixels or more. In general, unless you're really tight on space or know you're not going to need the resolution, set your camera to its highest resolution (8 megapixels in your case) and leave it there. You can always make a large picture smaller; you can't make a small picture larger.
See page 13 of the Cyber-shot handbook: http://www.docs.sony.com/release/DSCT70_handbook.pdf
May 21, 2013 | Sony Cybershot DSC-T200 Digital Camera
I want to know whether i can retrieve deleted photos from an internal memory Sony cybershot
It just permanently deleted and you cannot retrieve the photos.
Please back up your photos before they deleted to prevent recurrence
Dec 29, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
I have a sony cyberhot 12.0 and I accidentally hit "delete all" instead of one image. I deleted my whole memory card. Is there a way that I can undo that?
If you have a USB card reader then...
Install recuva software from the net and run it on the card.
This may recover some... if not all... of your data.
Aug 02, 2010 | Cameras
Sony Cyber-Shot DSC-S30 memory stick
Without being accusatory, it is likely that something bad happened to the camera (a drop, and accidental liquid spill, etc.). But the bottom line is that it sounds like you did all the proper things, and I'm sure you tried a full charge of the camera's battery. The good news is that a quick check of Amazon shows this camera to be fairly easy and cheap to replace at this point. Its listed as a 1.2 Megapixel camera which by today's standards is low enough in resolution, that you probably can replace it for about $20. Sony may be willing to service it, but I'll bet replacing it will be cheaper. Sorry to be a bearer of less than good news.
Jul 01, 2017 | Sony Cyber-Shot DSC-S30 Digital Camera
Deleted all my pictures in the Camera Album. Is there a way to retrieve these pictures
I don't think there is unfortunately. The only way you might be able to retrieve your piccies is if you have deleted them via the comp. Then you may still have them in your recycle bin. Sorry I can't be of more help.
Jan 11, 2008 | Sony Ericsson K800i Cellular Phone
Sony cyber shot
you most probably have your camera in slideshow.
if this is the case:
  1. turn the camera on and press the button to view your pictures
  2. press menu and use the left and right arrows/buttons to press 'slide'
  3. hit cancel
hopefully this will work.
good luck with it!!
Dec 07, 2007 | Sony Cybershot S650 Digital Camera
Deleting photos on a Sony Cypbershot 7.2 megapixel
as a matter of fact there is....
1).press photo replay button
2).hit the ''W'' button, it has somewhat of a checker board above it
3).press middle button, then hit select, green box will show
4).click middle button on all pics u want deleted
5).then simply trash it
hope this helps
if u need more info email me at:
steve_o_golfs@yahoo.com
Nov 19, 2007 | Sony Cybershot S650 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
136 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
