Question about Dell Latitude C640 Notebook
I changed my Cmos battery & my laptop would not start after tha
C640 did not keep time or settings. Replaced the reserve battery and now the unit will not start. I did not copy the bios before changing the battery.
    Scholar:
  • 122 Answers
Without battery, BIOS just gets reset to default and should not effect boot. There is a possibility that you failed to reconnect something important when disassembling the unit.
What exactly happens when the unit turns on?
Posted on Jun 18, 2009
Bios startup password
remove the cmos battery from motherboard once and then start.
Feb 10, 2014 | Thor 5 Year Warranty Compatible Toshiba...
Toshiba portege m100 hardwares not starting
Yes the CMOS battery needs to be changed. Then you can go into the BIOS and set the Date & Time.
The CMOS/BIOS will be set back to the defaults when you remove the CMOS battery and this may fix your problems.
Sep 05, 2012 | Toshiba Portege M100 Notebook
Password unloking
The simplest way to remove BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
If that doesn't work,you'll need a bios/cmos password recovery tool from http://www.biospasswordrecovery.com
Jun 04, 2012 | Computers & Internet
HI, I have a IBM Thinkpad R50e and i had a CMOS battery failure. After replace the battery it has now started to ask me to check the date and time and when i press enter it is asking for a BIOS...
Dear john, replacing CMOS Battery usually RESET password ( plug out your laptop battery,then plug out the CMOS battery. keep it out for 5 minutes.)
After 5 minutes by, put back on the CMOS battery. put it back all together. laptop battery the last one.
On the first boot you need to set the time and date. or by pass it by pressing ESC. >> If your Operating System goes >>> right click on clock task bar >>Adjust Date/Time >> set as you wish >> apply >> ok >>>RESTART your unit.
akee_akee@live.com
Aug 16, 2011 | IBM ThinkPad R50e Notebook
I need to change the motherboard battery on Dell 8100 laptop
sometimes there will be a compartment that can access the cmos battery sometimes not. This guide will show you in pic # 4 what the cmos battery looks like. If you look around the sit for a while you may find your specific laptop. I just don't have the time to look now.
Hope this helps.
http://www.insidemylaptop.com/take-apart-dell-studio-1537-laptop/
Oct 23, 2010 | Dell (S423) for Dimension 8100 (3F546)...
Changing cmos battery dellc400
Please refer to the following section of this laptop model service manual for an illustration & step-by-step instructions on replacing the CMOS (or reserve) battery:
http://support.dell.com/support/edocs/systems/latc400/en/sm/rsrvbatt.htm#1000202
Sep 10, 2010 | Everex Computers & Internet
The time and date has to be set after shutting off.
The BIOS battery keeps the Date and Time correct, if the battery is flat the date and time will be wrong or you will get an error date and time error.
You need to replace the battery with a new one. Your friendly computer shop can help you if you don't know how to change the battery.
Sep 28, 2009 | Dell Latitude C600 Notebook
I have a r40 ibm laptop problem is date & time error i replaced cmos battery update bios but still problem now
Assuming that you used the correct battery go ahead and unplug and replug the cmos batter back into its connector.
Go into the BIOS and set the date and time properly. Then unplug the battery and save the changes and exit.
See if the message comes back, if it doesn't then your good to go. If the message still comes back then the motheroard isn't keeping memeory at all.
Go ahead and shut off the machine for about 15 minutes. Then only plug the ac adapter up and hopefully the message stays away. If it does then that means the battery is good and your motherboard is good as well.
if you leave it off and then turn the laptop on and that error message comes back then you need to change out the motherboard.
Jul 17, 2009 | IBM ThinkPad R40 2722 Notebook
Have laptop that has black screen and says no boot device available every time i turn on computer. what can i do?
Boot to system system BIOS, reset defaults, save settings and reboot, see if the error goes away. If so, then the reserve battery on the mothebroard is bad. If no change, then reseat the Hard Drive, and try again. If still no change, a HDD replacement is likely
Jun 05, 2009 | Dell Latitude C640 Notebook
Dell Latitude C640 Laptop
get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system defaults.save changes then exit.
ps: defected processor could be the cause
Nov 14, 2007 | Dell Latitude C640 Notebook
Dell Latitude C640 Notebook Logo
195 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
