Question about Miele S7280 Bagged Upright Vacuum
S7280 bad on off switch
Switch is jammed
Dyson 25all floors, can you help please, brush not revolving, but nothing jammed around it.
It could be the upper switch, lower switch, belt or motor. The motor will not run if either switch or the motor is bad, if the belt is broken you can hear the motor turning.
Jan 01, 2017 | Dyson DC25 All Floors Bagless Upright...
Why does it have little to no suction power on carpet?
either your hose is stopped up or your motor is going bad and doesn't have enough power, first clean out your vacuum and check belts and make sure they aren't worn out and broken or stretched
Dec 13, 2015 | Miele S7280 Bagged Upright Vacuum
I am looking for a parts diagram for a Miele Upright S7280 (Salsa) vacuum
See if there is a manufactures web site and inquire if diagram is available or just Google for info with proper make and model.
Fist just search for vacuum diagrams then refine search for your vacuum but this not always easy can be confusing so might have to take it to vacuum repair business or if you have not dissembled it yet just make notes when you do. Its not as hard as it seems I have done it many times.
Oct 24, 2012 | Miele S7280 Bagged Upright Vacuum
What kind of upright or steam Vac should I buy which can make my carpet clean and SOFT?
I recommend looking at the miele S7280 for an upright vacuum cleaner and the royal RY7910 carpet extractor.
Jan 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The handle for my Eureka 5893 AVZ was getting very hot. Finally, the wires around the switch melted and the vacuum will not work. What is wrong? Is the switch bad? Nothing else appears to be wrong.
usually if a connection gets hot enough to start melting it is usually a loose connection or high current. more than likely the switch is bad if you replace it with the same type of switch and it gets hot check the motor. make sure it is clean and isn't jammed
Nov 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Cannot turn off the vacuum
I've read about the same problem with 3 Dysons in the past 10 minutes. One owner said a new switch (which is what you need) would cost half a new machine; which is way beyond ridiculous because a on off switch should be designed to last beyond the rest of the vacuum. I suggested if it were mine I would go to Home Depot and buy a toggle switch and either put it in or have someone put it in. Have you called a dealer about this. They may have enough complaints that to avoid bad publicity they would fix it free - if they were smart.
May 03, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Miele Mistral S7280 won't run after changing the bag
The Mistral range is the same as the new S7 that's just hit Europe. Have you made sure that when you turn on the vac on the handle that you've switched the carpet mode on? There's a separate button just under the power on button that activates the Carpet setting. Other than that check the sole plate where the roller brush to check for a blockage.
Jan 20, 2009 | Miele ART S920 Bagged Upright Vacuum
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Miele S7280 Bagged Upright Vacuum Logo
47 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
