Question about IBM Office Equipment & Supplies
How do I find the keyboard connectors on a wheel writter 5
  • IBM Master
  • 3,594 Answers
Raise the top cover, look down just beyond the keyboard you will see two flat connectors each about 1.5" wide.
DickyO
Posted on Apr 17, 2014
I have a BTC keyboard, Model #: 9000A. A wire became broken in the PS/2 male plug. I need a Schematic so I can solder on a new plug. I know this is a very old keyboard, but I like it and do not have the...
Unfortunately there is no color code for the cables in the PS2 connector. All the details that I can give you is that if this is the PS2
The pin #1 moves DATA.
The pin #2 is not connected or DATA2 (usually not connected)
The pin #3 is GND
The pin #4 is VCC for power (+5 VDC)
The pin #5 is CLK for Clock
The pin #6 is not connected or CLK2 (Usually not connected)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 18, 2010 | Computers & Internet
Problem of dvd/cd writter
check the IDE/SATA cable,if its connected,now u must to become sure from lens.maybe it need to cleaning.therfure,if after cleaning this problem still apear,so u must change the board or somethings in it by testing
Jul 07, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Input devises are not supported
If you are useing USB mouse and keyb, you may activate the support for legacy / USB keyboard and mouse in the BIOS. The less problematic way is to use the PS2 mouse and keyboard.
Positive rates are most apreciated!
SciPhinx
May 11, 2010 | Intel D102GGC2 Motherboard
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
How to remove keyboard
These are the steps you need to take to Remove the Keyboard for D631 Dell.:
  1. Remove the hinge cover.NOTICE: The hinge cover is fragile and can be damaged if extreme force is used. Be careful when removing the hinge cover.
  2. Open the display all the way (180 degrees) so that the display rests flat on your work surface.
NOTICE: To avoid damaging the hinge cover, do not lift the cover on both sides simultaneously. Removing the hinge cover in a different way than described may cause the plastic to break.
NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
3. Remove the three screws at the top of the keyboard.
NOTE: Lift the keyboard carefully to ensure that you do not pull on the keyboard cable.
4. Ease the edges of the keyboard out of the small detents on the sides, then slide the keyboard slightly forward to free the keyboard tabs from the palm rest.
5. Rotate the top of the keyboard forward and away from the display, and lay it upside-down on the palm rest to gain access to the keyboard connector.
6. If the keyboard cable is held in place by a locking arm next to the keyboard connector, carefully spread the retaining bracket away from the connector so that you can pivot the locking arm upward to release the cable.
7. Pull up on the pull tab to disconnect the keyboard cable connector from the keyboard connector on the system board.
Apr 25, 2009 | Computers & Internet
Ibm Weel Writer 5
Check to see if the ribbon is lifting up, if not there is a black gear on the right side of the printer wiggle it back and forth until it will move. If it is lifting put a multi part form a nd see if it prints on the copies if not the plastic on the print solinoid is probably broken they are available but a bit trigky to install.
DickyO
Dec 10, 2008 | Office Equipment & Supplies
Pages "roll"
Hi Randy329,
Thanks for your posting in FIXYA.
Method 1:
Please remove the Mouse connector from the PC cabinet. Reboot it.
Again plug it then try.
Also check your device manager if showing any yellow mark.
Method 2:
Go To Control panel -- > Select Mouse -- > Open the Tab --> Wheel --> Check its speed set it up 3-5. Please uncheck "One Screen at a Time", if selected.
Regards
ELLIN
Sep 12, 2008 | KEIO Mini Optical Scroll Mouse...
IBM Clicky Model M Keyboard
Viewing the male connector (on the keyboard or mouse cable), the pinout is:
In both cases, the pins are normally used as follows:
pin function
1 data (yellow)
2 (reserved)
3 gnd (blk)
4 +5v (red)
5 clock(white)
6 (reserved)
try to interchange wire from pin 1 and pin 5 if doesn't work.
Dec 27, 2007 | IBM (02K0806) Keyboard
Dvd writter not working
if the device is set up as a master and not a slave device it may be interfering with the hard drive. check the jumpers on the back of the device. If it's plugged into the same cable as the hard drive it must be a slave device. Otherwise, check your bios upon bootup to see if you it's trying to boot from the device instead of from the hard drive.
Nov 29, 2007 | Samsung WriteMaster SH-W162C DVD?RW Dual...
IBM Weelwriter 5
You probably need a new keyboard. Check and make sure the 2 keyboard connectors are secure in the main board. Open the top cover and look down by the keyboard and you will see the connectors. Keyboard costs about $ 75.00 to repair. Plus labor for a repairman to replace it.
Sep 26, 2007 | IBM Wheelwriter 30 Typewriter
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
