Question about Stihl Garden
Smells burnt,wat could cause this? - Stihl Garden
  • 27 Answers
It might be wood chips in around the muffler or around the
cooling fins or some thing leas in that area could be getting hot
Posted on Mar 08, 2015
I have a 2005 jeep liberty that has white smoke coming from the exhaust when idling and it smells like burnt firecrackers after driving it when I turn the engine off. Any ideas?
If it is the v8, the most common cause for greyish, white smoke is bad valve stem seals. True white smoke smells very sweet and is caused from coolant being buring in the combustion chamber.
Feb 23, 2016 | Jeep Cars & Trucks
When I start sewing by my Victoria electric sewing machine it smells like burnt rubber, what can i do now?
You just need to change the drive belt. It is slipping which causes friction, which causes heat, which causes the smell.
Aug 20, 2015 | Washing Machines
What would cause the transmission to all of a sudden slip?
You don't say auto or manual shift so it could be oil level low in auto box . if manual shift clutch plate worn out or adjustment of cylinder
Mar 07, 2015 | Cars & Trucks
What could cause the engine to buzz & smell like burnt rubber inside the car
check for failing drive belts and check for a pulley that is running hot or reluctant to spin freely
Aug 06, 2014 | 1998 Toyota Camry
My transmission fluid smells burnt
Never get your transmission flushed if your transmission fluid is burnt, that can only damage the transmission even more causing additional problems.
Jan 06, 2010 | 1993 GMC Suburban
Noisey and recently smells like rubber. maybe a/c
You may have a frozen bearing on the tensioner or belt idler. This will cause the belt to burn and smell. I think you are on the right track. I would remove the belt and spin the idler and adjuster by hand to see that they are free and don't have excessive play in them. Replace as necessary.
Nov 05, 2009 | 1999 Chevrolet Silverado 1500
Dvd shorted out with smells and all. when looked
It could be anything. What it sound like is maybe a capacitor has ground out against the cirsuit board. This would cause a melt down per say.
Oct 28, 2009 | Durabrand DUR7 Portable DVD Player
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Aug 07, 2009 | Whirlpool MH1141XM Microwave Oven
It smells like burnt plastic after 30 min
is it new? how old is it? burnt plastic is the smell a bad motor produces. dont worry, i dont think it will cause a fire, but a fan motor on its way out will stink!
if its relatively new, return it. if not, get a new one!
Aug 05, 2009 | LG L1004R Air Conditioner
My 1993 f-140, 5.0L 4wd, AOD, extended cab/short bed, has trouble going into reverse after the transmission heats up. When it's cold it goes into reverse just fine. When it's hot it will sometimes go into...
Check the fluid to see if it smells burnt. If it smells burnt or looks brown then change the fluid and filter. This is a common problem that if caught early may not cause severe damage. If the filter and fluid change do not help the you are looking at a rebuild soon.
Jul 23, 2009 | 1993 Ford F150 SuperCab
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
