Question about Quasar SP-2723 27" TV
Remote for Samsung model TC9895TB won't change channels
Volume will change but not the channel. I tried with the original remote and a universal remote
4 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Quasar VV-2009
Here is the link to the manual if you need it; http://service.us.panasonic.com/OPERMANPDF/VV1309.PDF check page 26 item 4 - vcr lock - just a possibility this may solve the problem, long shot. Let us know which remote you have and we may be able to find out how to program it for your tv. page 37 gives you contact details if you want to buy the correct remote. I suspect that with the correct programming, your universal should work fine though. Hope this helps :)
Posted on Mar 16, 2007
SOURCE: VChip Access Code Panasonic TV
cant figure out the code.
Posted on Jun 11, 2008
Remote won't change volume, channel numbers don't work
IF its the original remote for the device, the circuit board is just dirty and is not getting good contact. If its a universal then the codes may not be 100% compatible with the device or the remote isn't 100% compatible either.
Jan 23, 2014 | Emerson Used Original NH200UD Remote...
Urc22b remote control
Did you try this code-0866
Let me know if this worked.
Jul 02, 2008 | Televison & Video
LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
Dec 31, 2011 | Televison & Video
I lost the remote and can no longer change the input. The only buttons on the tv are power, channel up and down, and volume up and down. I have also tried changing channels past 0 and nothing is working. I...
Hello
It will be best for you to buy its original remote control. Universal remotes may also work with it, but some functions may not work properly. You can buy it from the Authorised Service Center for Toshiba at your town. Just give them the exact model number of you TV set [which can be noted at its back side]. They will give you the exact original one.
RCA RCR 311B model universal remote have setup codes for Toshiba. You may also try this remote. The codes are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
I strongly advice you to buy its original one. OK.
Sep 04, 2011 | Toshiba 27AF45 27" TV
We purchased a tv from a school channels only goes up to 02-13 cannot go any farther. We are using a universal remote that when we go to menu to channels it doesn't allow you to either enter or delete...
U can't do much on a universal tv remote.Only the basic mostly,like power on/off,channels up/down and volume up/down that about it.If u wanted more functions and controls and adjustments inside of the tv Menu for options like changing and adding functions.U must have the tv original remote to be able to do it.Try website like Remotes.com to buy the tv orignal remote.
Aug 29, 2011 | Philips 32MF231D Television
Lost remote to HTC Television....Model number HTV-021TB. The TV is currently stuck on channel search and am unable to make it to anything else......is there a universal brand remote that can replace lost...
No,universal remote only work for the basic like power tv on/off,numbers on the keypad,channel up/down and volume up/down only.Beyond that like inter functions of the tv will not work with the universal tv remote.Only the original remote can do that.Try website like Remotes.com to buy an original remote.
Mar 01, 2011 | Televison & Video
RCA TV model F27252GY. Don't think I have original remote. Need to set to input or video channel to use my new DVD. How do I do this?
You can try channeling up or down to get to channel 99.Rca in the past has used this to get to the video input. If this does not work you can buy a universal remote. In most cases, after programming the universal remote the major functions such as channel select, volume control and input select will work.
I hope this helps.
Skyassoc
Dec 12, 2010 | RCA F27252GY 27" TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Can't change channels. don't have remote. need to get channel 3 for cable
Use the buttons located on the TV to switch the channel to 3 or buy a universal remote from any local supermarket/drugstore. Or if it's not a rush, get the original from Ebay based on yor TV model
May 21, 2009 | Samsung TV Remote Control
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
Quasar SP-2723 27" TV Logo
32 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
