Question about Refrigerators
Ge tcc18jabbww bottom mount freezer
Fan noise on start up. does not appear to be compressor fan
  • 262 Answers
SOURCE: GE refer Model #TCS18PADBLBS Bottom freezer
the compressor should reset it self and the fan you just have to dig behind the rear panel for it chances are the blade is rubbing the shroud
Posted on Dec 03, 2007
suisboy
  • 175 Answers
SOURCE: GE refrigerator profile arctica Not cooling frige or freezer PTS25LBMARBB
well if the compressor dont have power so how could it work or cool?
Posted on Jan 16, 2008
22yooper
  • 828 Answers
SOURCE: GE Dss25KSRCSS
Sounds like your evaporator fan motor bearings are telling you it is time to replace the fan motor.
Posted on May 26, 2008
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
Ge gss22sgmd not freezing. Fans running at compressor and in top of freezer. compressor is cold and not seem to be running
Look for failed start components on the compressor or a failed overload protector on the compressor. Also check for loose or burned wiring on the compressor terminals. Make sure to disconnect power before removing the compressor terminal cover.
Nov 16, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Loud humming noise
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.
May 23, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Dec 29, 2009 | GE Profile Stainless Bottom-Freezer...
GE refrigerator runs extremely loud. Sounds like it may be coming from the ice maker or freezer area.
Dec 03, 2009 | GE Refrigerators
Why is there a loud knocking noise when my refrigerator shuts off? The volume of the noise differs each time that the unit shuts off
Nov 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
My ge bottom freezer is making a clicking noise and now its no longer cold
Clicking sound is the safety overload mounted on the compressor. which clicks off if the compressor won't start. Could be a grounded (bad)
compressor, or the start relay/ptc relay/or start capacitor bad. These parts are mounted on the compressor, and can be removed and taken to an appliance parts house for testing.
Oct 22, 2009 | GE Refrigerators
Our GE Profile refrigerator is intermittently making a "woodpecker" type sound lasting seveal seconds periodically throughout the day (and night).. At one point when I opened the refrigerator door, it...
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Dec 03, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
