Question about Mitsubishi WD-65733 65" HDTV
,white dots all over the screen, with no pattern.
When I turn on my tablet the screen that just shows my name and time and some dots. if you cannot do the dots in the correct pattern you cannot get to the main menu. Where can I get to the main menu
The "dots" on the screen are the security measure and require the correct pattern to unlock. This was enacted by someone (yourself or someone you know who had access to the tablet) as a measure to keep others out of personal information.
I would direct you to the insigniaproducts.com website for instructions on a hard reset of the tablet.
Keep in mind that the security solutions are designed to keep others out of your tablet. If this was your intention, it is working too well. Choices are limited...remember/figure out the pattern, or reset the tablet and loose all data.
I'm sorry this happened but there's really no "crack" or shortcut around the security measure.
Mar 15, 2015 | Insignia - Flex 8 inch Tablet with 8GB...
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Bright star pattern dots on screen
dust on the optical lens possibly or a defective light engine.
May 28, 2010 | Mitsubishi WD-73733 73" HDTV
What does it mean that my 66 pony has a green dot trany?
the '65/'66 C4, was known as the "Green Dot" C4 & has a different shift pattern to the '67/later C4's.
So your C4 tranny is the green dot which is an UPGRADED option. A better tranny better gears and stronger parts and what not, there was also the white dot tranny that was the cheaper or less performance transmission. As far as i understand the white dot was available for better fuel consumption HAHAHA which no one really cared about in 66 anyways.
In '65/'66 it was something like this:
P - Park
R - Reverse
N - Nuetral
White Dot - Starts in 2nd, automatically shifts to 3rd
Green Dot - Starts in 1st, automatically shifts to 2nd and 3rd
Apr 18, 2010 | 1966 Ford Mustang
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
Flickering dots on Benq PB6200 projector.
it's not the lamp. if you've replaced the cords and still have the problem, reset the settings to factory default to make sure the resolution matches. if still not ok, there may be an issue with the main board.
Oct 04, 2009 | BenQ PB6200 Multimedia Projector
SC 329 code Aficio 550
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the “Enter” key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
No picture
Hey man whatsup, I see very faint star like dot patterns, they shift around. This happens while using both cables.
Jun 24, 2008 | Microsoft Xbox 360 Console
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Jun 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi WD-65733 65" HDTV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
