Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Do not work
The printer doesnt read the cartridge .. any color i cant do nothing!! doesnt wanna print, doesnt want to copy.the only thing dat can i do is scan! plzzz help me!
    Scholar:
  • 122 Answers
Thats odd, the Brother ink cartridges do not have heads attached to them, they are just ink tanks. Check to make sure that it is fully seated. also make sure that the cap was punctured when it seated. Clean any visible contacts with a q-tip & rubbing alcohol.
If this does not work, try another cartridge, you may have a bad one
Posted on Jun 18, 2009
My epson stylus NX110 is printing blank pages
Printer heads clogged or cartridges are empty or defective.
Feb 10, 2014 | Epson stylus nx110 All-In-One InkJet...
Cannot make the printer work after I changed the ink cartridges?
You can validate the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=440
1. While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
2. Release the Power button.
3. The 'Tap 41' diagnostic test print should print.
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout. http://inkjet411.com/?page_id=434
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Sep 01, 2013 | HP Deskjet F2480 USB 2.0 All-in-One Color...
Will not copy
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Apr 20, 2013 | HP Officejet 7210 All-In-One InkJet...
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
The printer marks an error with the color cartridge, i open it check it and still has ink, but still doesnt wanna print, what can i do? Its a lexmark x 2695
It could be that the color cartridge has gone bad now. Try to re-seat the color cartridge in the printer. And if that doesn't help, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Sep 11, 2011 | Lexmark X2600 InkJet Printer
If black or Color cartridge is empty in canon MP145 all in one printer, so scanner is not scan. how to scan without cartridge?pleae help me.
Hi, The scanning unit is independent from printing unit. You can scan even with empty ink cartridges. At sametime, if you wanna copy documents, you need both scanning and copying units to work. Try reinstalling the Driver from the provided driver CD.
Sep 02, 2010 | Canon Office Equipment & Supplies
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Copier feature (Black or Color) only produces a Black page
I beleive you are not able to make a color copy, once try to scan from the computer or all-in-one to check whether the scanner mechanism is working properly or not, if the scan comes out fine then remove the color cartridge and clean the copper contacts of the cartridge with soft cotton cloth and also check the ink level of the cartridge, if the issue persists replace the color cartridge and if even the scan does not comes out good then there is an issue with the scanner mechanism.
May 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Can this machine COPY from the Black Cartridge only.
Click Start - All programs - HP - HP Director/Solution center.
In HP Director/Solution center. Click Settings - print settings - printer settings . Click on the Colors tab. Enable the option Print in grayscale and Black print cartridge only.
This is the only way to print with single black cartridge.
Thanks
Dec 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
