Question about Speed Queen AWS45NW Top Load Washer
Agitator quit working
The agitator quit working. How do I fix it?
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Mar 06, 2012 | Washing Machines
My top load washer quit agitating, how do I pull the agitater off to check for problems ?
Depends on the type of washer but on some if you take out the softener cup from the top of the agitator there is a bolt or nut holding the agitator on. After you take the nut or bolt off the agitator should lift straight out. There may be something, a piece of debris from a previous cycle, causing the agitator not to operate properly. Hope this helps.
Dec 03, 2011 | Hotpoint Washing Machines
Kenmore 80 washer extremely poor agitation works if pressing
YES THERE IS! REMOVE AGITATOR BY TAKING THE SCREW OUT UNDER THE CAP. PULL UP ON AGITATOR TURN UPSIDE DOWN WILL FIND 4 AGITATOR DOGS REPLACE THESE AND REINSTALL AGITATOR WILL WORK LIKE NEW PART NUMBER IS 80040
Apr 30, 2009 | Kenmore Washing Machines
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Agitator won't move
I think just from the sound of it that one side of the motor coupling has rounded off. Does the bottom of the agitator move?
Mar 07, 2009 | KitchenAid KAWS850L Top Load Washer
Top agitator not working properly
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Agitator dogs part number is 80040
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My agitator quit working and i took the agitator
theres a belt under neith the unit that is activete whats called wig wags. they activate and that is what activaes itt. v
Jan 11, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer not agitating
when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
Dec 11, 2008 | Washing Machines
Agitator problem
Check and see if it spins freely in both directions. If it does, this means that your "dogs" are worn out in the top agitator. This is an easy fix. You just get the new ones (usually 10$ or less), pull the top cover off the agitator, then pull the center cap off inside of the agitator. Then you just remove the center bolt and pull the whole top agitator off. You will see the 4 plastic dogs right on the top of the agitator.
Oct 16, 2008 | Washing Machines
Speed Queen AWS45NW Top Load Washer Logo
35 people viewed this question
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
