Question about Konica Minolta Bizhub Pro 950 Toner TN911
Dear Sir, I have Minolta BizhubPro 950...the problem is dark copies on the paper.....can u give an email address so i can send u the picture problem on my copier machine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Needs a rebuild. Call a service technician. Your developer is old and needs replaced along with a bunch of other things.
Posted on Nov 14, 2014
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Nitrotrike
  • 589 Answers
SOURCE: Konica Minolta 7022- How to clean- Getting Dark Lines on Copies
Beings as it is close to 100k, it is due for a PM (preventative maintenance) kit to be installed (this model has a 100k PM cycle), and also a web, corona wires, charge grid, and feed rollers (if worn) should be replaced at this point, and of course cleaned.
The drum and developer "should" last 200k (this can vary greatly).
$200 for a general cleaning on that series machine... that's entirely too much, and he will most likely tell you it's due for a PM. A competent technician would be able to install the kit, replace the above parts in under 2 hours easily.
I wish I could be of more help, but given that is almost at the end of its PM cycle, it could be anything.
Posted on Feb 12, 2008
SOURCE: Konica 1216 Phocopier, big problem!!!
MY COPIER FLASHES P.26 CODE WHAT I DO?
OR ISSUED TO RETIFY IT
Posted on Aug 27, 2008
  • 15 Answers
SOURCE: Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Posted on Jun 09, 2009
  • 17 Answers
SOURCE: The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Posted on Jul 07, 2009
How do I send a received email with a number of old email address and the text has a number of pictures. I do not want to send all the old email addresses to my new recipient, but I want to send all
Have you tried to copy the received email of the old email address and paste to your new recipient, if you are concerned about hackers and you are sending a email/s to multiple recipients use BCC (Blind Carbon Copy) and request your recipients do the same.
Hope this helps you.
Feb 11, 2015 | Computers & Internet
Can't send and receive a email
You have to fax email copy it then fax. and the same the other way print it to paper and send it. It's a fax machineIf you have 4 in one then you can have a email address just for your machine
Mar 11, 2014 | Panasonic KX-FB421 Plain Paper Film Fax
My problem is with a bizhub 181, because the copies are opaques. I already check and replace the imaging kit. but is damaged.
Sir/Mam,
Is the machine set up as a printer also do print come out ok? Copies from the big glass ok? Mite be the electrical connection to the sponge roller on the right side door the sponge looking roller is what helps the transfer of the image off the drum to the paper. The paper is guided between both the drum and that sponge looking roller to place the image on the paper. There is a high voltage applied to that roller during the copy cycle. the connection for the roller is on the copier at the rear where the right side door closes
Oct 05, 2013 | Konica Minolta 950-281 Genuine Konica...
Philips tv schematic model: 21PT3324/71
Send your email address to me by Fixya and get back a copy of the schematic by return mail.
Jan 08, 2013 | Zenith Z32X31D 32" TV
What does the symbol Cc in an email mean? what should be written on the space beside it? is it the name of the person sending the email? what about for the ''subject''? shud i write here a little about my...
The cc: stands for carbom copy and is a throwback to the days when you would place a sheet of carbon paper between two sheets of plain paper to make a copy if what is written on the top sheet.
To answer your question, if you want to send a copy of the email you are sending you place the email address of the person to be copied in the cc: field.
The original recipient will see that the email was addressed to him/her and also see who you sent copies to.
Nov 07, 2009 | Cell Phones
Makes dark line on paper
if you are using your doc feeder check and see if there is anything on the small glass the one that is about an inch wide other then that could b fusing or drum issue
Jun 21, 2009 | Konica Minolta DiALTA Di200 Copier
ERROR CODE SC45-20
HAVING A REPORT CODE SC 45-20 HOW TO SOLVE IMMEDIATELY FOR PRINTER/COPIER BIZHUBPRO C500
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica minolta e-mini driver
sir how are you i have a e mini camera but i have no winxp driver so sir plz send me my e mail address = sea_rose45@yahoo.com
Dec 28, 2007 | Konica E-Mini Digital Camera
Please help
non scarica le foto della memoria interna
Feb 03, 2007 | Kodak EasyShare CX7330 Digital Camera
Konica Minolta Bizhub Pro 950 Toner TN911 Logo
52 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
