Question about Element Electronics Televison & Video
I have an Element Full HD LED TV Model Number ELEFT406 40". At this time I am only getting half a screen, the other half is black. I was wondering if there is an adjustment I can make to correct this problem. The left side of the screen is the one that is black. The only other solution is to send the set back to Element for a new one and the shipping charges are to expensive. They would probably send me a another TV with the same problem anyway.Thank you,Drew
lukster
  • 217 Answers
SOURCE: half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Posted on Feb 17, 2007
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
  • 52 Answers
SOURCE: 42" Philips plasma screen goes black
you need to replace y-sustain board.
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: high def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Posted on Apr 19, 2009
dave1645
  • 834 Answers
SOURCE: HD broadcast picture is not full screen. How do I
go into your customers setting and change you aspect setting to either full or auto
Posted on Sep 17, 2009
HOW CAN I FIX MY WESTINGHOUSE 22 INCH LED TV? IT HAS HORIZONTAL LINES COMING UP FROM THE BOTTOM 1/3 THE WAY AFTER IT HAS BEEN ON FOR 10 OR MORE HOURS.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 13, 2017 | Westinghouse Televison & Video
Vizio e371va screen NOT TURNING ON
Sorry to hear that...now a days it,s cheaper to replace then to fix...I had that problem on my first HD TV..a element brand...No hope....trash it went
Aug 13, 2016 | Vizio E371va 37-inch Full Hd 1080p 120 Hz...
Remote code for Bauhn ATV-BA32DV2
bauhn p v r setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... bauhn universal remote control tv but i had vivo tv how ican set up that The universal ... ATV-BA32DV2, have done initial setup, but screen says have to scan ...
Remote code for BAUHN TV model ATV-19HED - TVs - Home theatre ...
forums.whirlpool.net.au > Home theatre > TVs
WhirlpoolDec 14, 2014 - I've mislaid the remote for this TV and I was wondering if anybody new how I could get hold of BAUHN remote IR codes. I've looked everywhere ... 32" (81CM) HD LED LCD TV $222
May 29, 2014
Bauhn 24" Full HD LED LCD TV with DVD
Jan 12, 2013
More results from forums.whirlpool.net.au
[PDF]32" (81cm) HD LED LCD TV
Feb 03, 2016 | Televison & Video
How to fix the problem of half black screen on my toshiba led tv?
On your TV remote go to menu , either video or picture settings and make sure it is on HD ( high definition )
Aug 01, 2015 | Toshiba Televison & Video
My Element 32 inch tv has black screened.
hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
Sep 09, 2012 | Televison & Video
LG Plasma TV Full HD - Inbuilt Tuner
Google the model number parts--suspect a sustain type board as these sets use two boards---each drives half the screen for picture.
Apr 07, 2012 | Televison & Video
1 dg board, (stv 5v sense time out). ........ive
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
Jun 27, 2011 | Panasonic Televison & Video
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
46 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
