Question about Plantronics Radio Communications
Can you pair plantronics cs70 nc to a cell phone?
Is it possible to pair the plantronics cs70 nc to my cell phone? If so, How?
4 Suggested Answers
  • 32 Answers
SOURCE: plantronics cs70 nc stop working
Make sure that the power is connected to the headset.  You can tell it's connected because there will be a red solid light on the left side of the front of the charging base.  Check the power cord for any frays and make sure it's plugged into the wall.  If it is, then try the following:
A system reset:
1.  Lift the headset off of the base. 2.  Make sure the headset is turned off.  The green light will not be on on the base. 3.  Hold down the minus button at the same time as the call answer button on the headset.  Hold them down for at least 10 seconds.  An orange light on the headset will flash several times.  It should go off when you let go of the buttons.  If the orange light stays solid, push the minus button once. 4.  Put the headset back in the charging cradle.  Leave it for 30 seconds.  Lift it back out of the cradle and try using it again.
Posted on May 22, 2009
SOURCE: Need a user manual for the Plantronics CS70 NC
http://www.plantronics.com/media/media_resources/literature/user_guides/cs70_ug_en.pdf
Just copy and paste that link above in a browser and get a 22 page official manual from Plantronics.
:O)
Posted on Jun 15, 2009
wb91
  • 126 Answers
SOURCE: I have a CS70 NC
If all the dials are in the correct place, check one more time. It could be that there is interference from your phone or your phone line. If all else fails contact the company you purchased it from, and have them do support on line with you.
Good luck from Headsets Direct - 800-914-7996.
Posted on Aug 23, 2011
Mistake sorry everyone, plantronics voyager pro x cs70 .cannot get to work on my nokia c2-01 please help
Oftentimes there may be interference from other bluetooth devices on the phone. Disable them first, disconnect the battery from the phone for 30 seconds (helps to reset) and follow the pairing instructions from the link below.
Plantronics Voyager Pro User's Guide
Good luck from Headsets Direct!
Sep 30, 2011 | Plantronics CS70 Wireless Headset
I have a CS70 NC and all of a sudden one day people started complaining abot me sounding like a cell phone cutting in and out. I double-checked all of the settings adn finally gave figuring the battery...
Aug 22, 2011 | Plantronics Radio Communications
The headset picks up but it doesnt answer the phone. CS70 NC headset.
If it's not answering the phone, your phone may need to be programmed for auto-pick up so that it automatically opens the telephone line when you turn on your headset. Also, make sure the round compatibility dial (located to the left of the base) is set right (not between numbers and most phones work on setting #1).
Aug 09, 2011 | Plantronics CS70 Wireless Headset
The Headset Lifter won't pick up the calls. Nothing happens when I push the ear button to lift it up. I thought maybe it wasn't fully charged when I tried it yesterday. At that point, I made...
If the CS70 headset has a charge and beeps when you press the call control button, you may just need to re-pair or re-subscribe the headset to the base unit. Here is a link for the pairing / subscription instructions:
Plantronics CS70 Pairing Instructions
If the headset is not charging, the internal battery may be worn out and the headset may need to be replaced (the battery is hard wired and is not replaceable). The replacement headset is model 72910-01. Below is a link where you can purchase the replacement headset.
Plantronics CS70 Replacement Headset
Jun 24, 2011 | Plantronics CS70 Wireless Headset
I have a CS70 NC./ no lifter. What is the set up procedure to use my headset without lifting my phone handset. With the base plugged into the headset port of the phone.
If the Plantronics CS70N wireless headset is plugged into the headset jack on your phone, you will need to push the headset button on the phone and then the call/control button on the wireless headset.
Jun 10, 2011 | Plantronics CS70 Wireless Headset
Plantronics CS70 is paired with the Yealink EHS36 it will not pick up the line, you can hear nothing but the EHS36 clicking
You are using a Jabra Electronic Hook switch with a Plantronic's headset, they are not meant to go together. Depending on what phone and model you have would depend on the EHS that you would need.
Plantronics HL10 Handset Lifter
May 05, 2011 | Plantronics CS70 Wireless Headset
Need to pair to mobile phone is that possible if so how
The CS70 does not have Bluetooth, so it cannot be used to pair to a mobile phone.
Mar 01, 2011 | Plantronics CS70 Wireless Headset
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Oct 14, 2010 | Plantronics CS70 Wireless Headset
:O)
Dec 01, 2008 | Plantronics - Bluetooth Headset Plus Base...
Radio Communications Logo
176 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
