Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Fitting a hulk 30 ltr tank and line to a 4 hp outboard motor
Ibought a tank with line but the fiiting does not seem to match the outboard do i need a further fitting? also do i bypass the small 1.4 ltr fuel take or do i somehow feed the 30 ltr huilk tank into it?
  • 285 Answers
Yes you will need a fitting suitable for your outboard brand. They are usually sold by motor brand (and sometimes motor size). What brand and year model 4hp do you have? If that motor has an external fuel hose fitting on the outside of the motor, it is likely you would just use that to feed fuel into the motor.
Posted on Jun 20, 2009
Problems getting gas from gas tank to my outboard 15 HP 4 stroke Mercury.
need to clarify your statements
you say-- have replaced flexible lines from the tank to the engine --replaced the primer bulb
well that is all the rubber hoses from the tank to the pump on the engine
Then you further state only parts not replaced are the connections between the
gas tank and the motor and the tank itself
Well that connection is the rubber hoses that you stated were already replaced
So this may help rubber in outboard motors rots internally so replace all rubber from the tank to the motor, overhaul the fuel pump on the motor and all the rubber hoses from the pump to the carby/s
the primer bulb will not pump fuel if the tank vent is not open so that is one reason you feel like it is pumping air when priming
best advice is --no e-mix fuels to used on out board engines
Sep 18, 2017 | HP Garden
Where is the oil filter located on a 2004 Yamaha outboard two stroke motor
Some links including a video of how to change the filter. In such questions horsepower is useful along with year :>) Oil filters would only be on a 4 stroke though to protect the engine oil. Your two stoke doesn't have filters in the lower unit. There may be a strainer in the two stroke oil tank.
check page 31 here
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-03_1415.pdf
Google
year make HP manual
http://www.bing.com/search?q=oil+filter+located+on+a+2004+Yamaha+outboard+two+stroke+motor&form=PRHPR1&src=IE11TR&pc=EUPP_HRTS
Jul 04, 2016 | Yamaha Yamalube Outboard Oil Change Kit...
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
174 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
