Question about Miele Washing Machines
Miele w460 flashing rinses and anti-crease/finish
SOURCE: machine wont programme
I hate my meile washer
Posted on Jul 12, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
localwonder
  • 6784 Answers
SOURCE: NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
Posted on May 11, 2009
  • 53 Answers
SOURCE: hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Posted on Oct 26, 2009
  • 70 Answers
SOURCE: my miele w842 starts its programme and then the
Firstly check the brush module is correctly located this can be done with a multimeter. you should get continuity between sets of pins. first pin on right of module is earth moving to left next two are the overload(continuity) next three are field coil windings(continuity between at least 2 out of 3 spin speed dependent) next two are brushes(continuity) next two are the tacho.(500 ohms) If this checks out OK. Then most likely you require new power electronic which clips on the back of control electronic
Posted on Aug 09, 2010
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Flashing rinse light on meile 864 and anti crease/ finish light comes on.
If you are sure that you made no mistake in mounting the brush cap back on the motor (check the four pins), most probably the electronic EL200 is defective.
This happens often in this type of machine when the shock absorbers are worn (after 10 years).
You can check this by measuring the continuity in the little 6.3A fuse that is on the EL200. If it is blown, you may get the PCB repaired for 55 Euros + shipping (see link below). You also have to replace the shock absorbers (32 Euros) to get a full year guarantee.
Miele Reparatie EL200
Feb 11, 2014 | Miele W864 Front Load Washer
Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
Jan 26, 2014 | Miele Dryers
Cycle is not finishing and the red lock light and green anti crease light is flashing
I am sorry, I have no specific manuals or experience with this machine. Another expert should pick up on this and hopefully will provide you with a good solution.
Nov 25, 2011 | Indesit Washing Machines
The dryer is showing anti crease on the LCD. What can i do to reset or fix the problem.
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
Jul 22, 2011 | Miele Novotronic T1515A Electric Dryer
My Miele W487 does not dispense the fabric conditioner. The syphon in the dispenser is clear and works fine if I manually fill it, however, it does not appear to fill when in use. I have used a toothbrush...
Hi - there are a few things that may possibly contribute to the problem.
Its my suspicion the solenoid valve(s) located in the back of the soap dispenser housing is faulty, this would normally be brought into the cycle as required. There are six solenoid valves performing certain functions during the cycles, the unit for fabric dispenser has to be faulty.
Its a bit difficult to determine, you will require some assistance with this from a Miele Serviceman, who has a Miele diagnostic program to check a few things in the process and verify the actual cause. Unless you know someone more than capable to help as these machines are unique.
Cheers
Jun 25, 2011 | Miele W487 Front Load Washer
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Meile W 844 Drum not turning
Its probably the motor brushes you need to replace them
May 10, 2009 | Miele Novotronic W1918A Front Load Washer
Hi - we have a Miele T284 tumble drier which is 2 weeks old and seems to have developed a fault. The machine stops after about 30 seconds with the buzzer going and Finish/anti crease light on. This is...
if this unit is only two weeks old,its safe to say its under warranty ,if you can't remedy this yourself by consulting the owners manual,contact the place of purchase &/or the manufacture,i'm sure they will be glad to repair or replace the dryer.any attempt by you or any unqualified person to repair this will void your warranty.hope this helps.thanx for using fix-ya
Nov 25, 2008 | Miele Washing Machines
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
