Question about Hampton Bay AC416-NI 56'' Frontera Natural Iron Fan
Does it need a remote because fan only works when light is on
Connecting wires
You are just missing one wire to all the circuits. The ones that work are good ... add the one wire that is not hooking up to the others to complete a serial circuit.
Mar 30, 2017 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
INSTALLEDMFAN BUT DOES NOT WORK CHECKED WIREING IT IS FINE THE REMOTE MAY BE THE PROBLEM CTHE LIGHT ON THE REMOTE DOES NOT LIGHT THE FAN IS COMPLETLY DEAD WHAT SHOULD I DO BESIDES RETURNING ITHEM
If the light on the transmitter does not light you need a new battery. That light is a battery indecator light. If it still doesn't work then you need a new transmitter.Hunter parts 1888-830-1326
Apr 06, 2013 | Hunter Fan Co. 60 In.Brushed Nickel...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Fan remote nor lights work.
FIRST CHECK THE WIRE CONNECTIONS IN THE FAN ARE NOT LOOSE ,IF ALL CONNECTIONS ARE GOOD THEN I WOULD SUGGEST YOU REPLACE REMOTE.
Nov 08, 2009 | Dryers
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
Hampton 52" ceiling fan Bentley
Press any of the function buttons on the remote control and see whether the red light on the remote comes on. If it does, check the dipswitch settings on both the remote control and the receiver (located in the ceiling fan). If the dipswitch settings are the same and the fan does not work, you'll need to replace the receiver. If the red light on the remote does not come on, you'll need to replace the remote control.
Oct 09, 2008 | Hampton Bay 52 In. Bentley, MICA, Oil...
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Light not working by pull chain or remote.
I would try removing the remote part. Connect the two main (light & fan) wires direct to your house main. Then if the pull chain works then you just need a new remote unit.
Feb 13, 2008 | Heritage (5BUW52NK2YQ) 52" Ceiling Fan
Hampton Bay AC416-NI 56'' Frontera Natural Iron Fan Logo
19 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
