Auto reverse When I am pressing the play button it is permanently switching the auto reverse function. Spinning forward and backwards is ok but not playing. I have tried to repair the item. I thought it is the belt and replaced it. After replacing it the same problem was still existing.
  • Audio Player... Master
  • 1,267 Answers
You do not list brand and model but it is typical that the belt replacement is missing the mark in that the reel rotation sensor is not detecting rotation of the reel table and therefore trying to go the other way. The reels have to be turning in play mode. If they do not auto stop or the reverse function thinks the tape is at end.
Posted on Jan 02, 2015
  • 883 Answers
SOURCE: Teac W-505R left deck not functioning
possible that the drive belt has broken or is slipping. Disable all outside noise and listen closely as you attempt play or fast forward button. can you hear a motor turning? I have replaced a drive belt in these but may be hard to find except maybe on ebay (search for an as-is unti for parts only).
Posted on Sep 17, 2007
CLARKPINK55
  • 71 Answers
SOURCE: play button no response fast forward and rewind work
THE capstain belts need changing to operrate the tape lifter mechanism
Posted on Dec 17, 2008
SOURCE: Dual Cassette Deck won't stop or auto-reverse
My Tascam 202 wr need to replace belts on recorder of duel deck? what is the best way
Posted on Jan 04, 2010
shibuda
  • 1812 Answers
SOURCE: I have a Technics Auto
You thinking is right,just change the belt which is smaller.
Posted on Mar 11, 2011
dunnbiker
  • 8546 Answers
SOURCE: Although I placed both ends the necessary sensing
I'm pretty sure the auto-reverse is NOT supposed to work during recording. What would be the point since it only records in one direction?
And I'm pretty sure there's only one reverse sensor, usually to the left of the heads and not necessarily on a tension arm. The sensor foil is supposed to be on the non-oxide side of the tape so it will adhere better and never contact the heads.
This picture of a GX-635 shows a typical transport ...
http://www.oaktreevintage.com/web_photos/Reference_Photos/Akai_GX-365D_Front_Face_Off.jpg
There's a knob for how the auto reverse. Is it set correctly? I believe infinite forward / backward play is possible if you have the knob set properly, a sensor foil on the tape and the tape counter set to 0000 at the beginning of the recording.
Posted on May 13, 2011
How will delete files?
You can erase the file by following steps:
  1. Press the Folder button to select the folder.
  2. Press the Forward or Backward button to select the file to be erased.
  3. Press the Erase button.
  4. Press the Forward or Backward button to select the 'Yes'.
  5. Press the Play button.
Nov 29, 2013 | Olympus VN-4100PC Digital Voice Recorder
Although I placed both ends the necessary sensing foil ,when choose auto-reverse with my Akai GX-636 RtR only the right tension arm sense the foil and blocks without reversing.When in recording mode it...
May 12, 2011 | Audio Players & Recorders
Deck plays forward, fast forward and fast reverse O.K., but does not play backwards.
I don't have any quick answers as this is a newer deck than when I worked for the company- I would have to see the deck to determine the fault. Do you have the continuous reverse switch on -maybe that is it.
Oct 19, 2010 | Teac R-H300 Dual Cassette Deck
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
My sony nw-507 is stuck going backward through tracks.
It sounds like the hardware. Maybe something sticky made the button stuck, so try light rubbing alcohol with a cloth gently around it, this will get rid of any residue.
If this doesnt help, then the button is broken and not much you can do.
Mar 09, 2010 | Sony NW-E507 MP3 Player
I dont have my manual with me .Could you please tell me how I view the 'photo that I have just taken on my Samsung S630
■ If the memory card is inserted in the camera, all the camera functions apply only
to the memory card.
■ If the memory card is not inserted in the camera, all the camera functions apply
only to the internal memory.
■ If you have turned on the camera by pressing the POWER button, you can press
to Recording mode.
■ You can turn the power on with the play mode button. The camera is turned on in
■ You can set up the PLAY mode function by using the camera buttons and LCD
monitor.
● Playing back a still image
play mode button ( ).
100-0007
3. Select an image that you want to play back
by pressing the LEFT / RIGHT button.
※ Press and hold the Left or Right button to
fast forward the images played.
AND here is the manual in free downloadable form
http://www.fixyourownprinter.com/forums/inkjet/24191
Oct 09, 2009 | Samsung Digimax S630 Digital Camera
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Setting the clock on my baby g shock watch
Press & hold the adjust button until the time starts to flash.
Press mode button to select hours.
Press forward or reverse button to move hour backward or forward.
Press mode button to select minutes.
Press forward or reverse button to move minutes backward or forward.
Repeat the process for the month/dte/dy/yr
Press adjust again when finished
Mar 09, 2008 | Watches
66 people viewed this question
 Grubhead
Grubhead
