Question about Canon Wireless PIXMA MP495 Photo All-in-One Inkjet Printer
Ssid Hello I need to change my new ssid: ATT0385 How do I do it ? Thank you
I need to change my ssid cause my cameras wont sink
You need to login to your Wireless Router Admin Console (use default gateway address, usually 192.168.1.1 or 192.168.0.1) enter your username and password (sometimes found on the back of the router, if you haven';t changed it), go to Wireless Settings and under SSID/Broadcast name, type in a new SSID.
Mar 01, 2017 | Computers & Internet
Got new internet service. Now I can't connect the internet to the wii!! I need a SSID and I don't where I get that from
Hello! SSID stands for wireless network name. This means that whenever you wanted to connect to your router, you need to know your SSID to join your network. This works very similar in connecting a new laptop to your router. Below is an example in checking the wireless network a Windows 7 Operating System is connected to. "RABBIT and maculit" are examples of SSID. I hope this helps.
Sep 16, 2011 | Nintendo Wii Console
What is ssid?
Aug 07, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Were having problems connecting our Wii to our router we have a Cisco E2000 router. on the Wii a screen pops up when im trying to connect that asks for a SSID n i cant find that on the rounter or anywhere...
Your SSID is the name of your wireless network, which you probably entered yourself when you set up your router. If you didn't change anything, its probably something like generic like: "ciscoxxxx" or "linksys".
Jul 24, 2011 | Nintendo Wii Console
F7D8302V1 is only broadcasting the 2.4ghz Wireless G SSID (SSID = Belkin.5d94 ) The 5ghz Wireless N SSID is set to "MyTV". This SSID doesn't show up as broadcasting on any devices...
This might not actually be an issue. The 5ghz band is not available on a lot of devices. Unless your device says it supports 5ghz, you will not see it. All cell phones I know of, blackberry's, iphones, etc... use wireless G, or N 2.4ghz. New devices like HD streaming video players, media extenders, 2010-2011 MAC's and some new PC laptops support the 5ghz band. Your configuration screen shot looks fine. Verify that your devices support 5ghz.
My MAC book PRo 2011 supports 5ghz and so does my Asus Laptop. These two devices connect to the 5ghz and all my other devices, including my blackberry, connect to 2.4ghz.
Regards, Chris
Jul 01, 2011 | Belkin (F5D7231-4) Wireless Router
I have changed my SSID number and now cannot use my printer wirelessly. How do I change the number?
> how do I change the number?
Huh?
Or, do you mean that you need to use the buttons and the LCD panel on the HP printer to specify the "new" SSID?
Nov 04, 2010 | HP J4680 Office Jet All-In-One Printer
Help me ! I lost my Belkin Wireless Play Router (F7D4302) SSID and passphrase that comes on a card with the router before i set up my router ?? so i can't set up and use my router please if you...
Hi this is not a problem any more for you
  1. the password and SSID default is not important any more
  2. lets we make it manually
  3. open one explore and erase the address bar htt://xxxxx
  4. need to be blank the address bar and type (router)nad press enter
  5. belkin setup page will be open and you can make all configuration needed for you new SSID and Password
  6. left side under the Logo Belkin you will see a the menu for setup
  7. go to channel and SSID click and if the router ask you for some password just click Submit and the next page will be open
  8. for default SSID is Belkin XXXX now erase all and type your new SSID one name only no numbers and click in to apply changes
  9. after that go to left side again and next to channel and SSID line there is a Security click again and if ask you a password remember just click on to submit(no password needed)
  10. Ok now you are in security mode click the security mode and change to 64bitwep or WEP only after that will appear one area were you need to input your new password 10 numbers and click apply changes.
  11. Next disable wife protect setup and firewall in to your router .
Ok your new SSID and Password is setting just look for your wireless signal and be connected
any problems just ask me for a remote your PC.
Good Luck don't forget to rating me kk thanks
Oct 21, 2010 | Belkin Wireless Play Router (F7D4302)
I have a NETGEAR router and I need the SSID and the type of sceurity. With the password. Can you help
Looks you havent configure your router. To get SSID and security key you have to configure it on your router.
You have to manually assign SSID on your Wireless Settings and Select proper security like WPA or WPA2 and assign preshare key ( security key). After assigning when you search for SSID on your Laptop or wireless computer it will you SSID you configured on your Router if you click on the SSID to connect it will ask you security key, supply the preshared key you configured on router.
If you are very new to router you might need to refer manual
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
If you know how to configure routers follow below link
http://www.ehow.com/how_5220934_configure-netgear-wgr-v.html
May 23, 2010 | NetGear WGR614 Wireless Router
Hello, I have Edimax br-6204wlg router that doesn't send wireless signal. The router connects to internet but there is no wireless signal that comes from the router. It shows on the router that there is a...
You will need to connect to the router with a cable and access the router configuration and setup. Make sure it is set to broadcast SSID and that it is not using WEP or that you have the same WEP key and Network SSID configured in the laptop. Next you need to check that the channel it is using to broadcast SSID information is not channel 6 if you have an HP laptop. Change that to channel 10. Of course the first thing you need to double check is that your wirelss on the laptop is turned on and capable of connecting to the router. If the router is using 802.11B and your laptop is only capable of using 802.11G they will never see each other.
Oct 30, 2009 | Computers & Internet
SSID
Hello JediSentinel
(01) Change your SSID and then, turn off SSID broadcasting.
(02) If your router supports this feature, set up a wireless access list. This is a list of MAC addresses of wireless devices on your LAN that are allowed to connect through your router's wireless radio. They will be the only wireless devices allowed in. (Note: If you are using any wireless repeaters, doing so will defeat the wireless access list.)
(04) Set a STRONG password for your router login and change it often. There are password generators on the Internet that you can use if you don't have one.
If you need any help w/ any of these steps, just let us know. Please, provide us w/ the make and model no. of your router as well.
Please, let us know if this response was helpful for you or, of course, if you have more questions, etc on this topic.
Thank you
BJ
Apr 05, 2008 | 2wire 1800HG Router (RG1800HG00)
Canon Wireless PIXMA MP495 Photo All-in-One Inkjet Printer Logo
12 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
