Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
San disk not showing up on the computers
I am plugging in my usb flashdrive and nothing pops up or is in my computer... I wanted to see if i could still retrieve the data somehow.. it is mostly pictures and microsoft word documents.. thank you
  • soniakmaeda Jun 18, 2009
    thank you all for your advice but I think it is my usb that is not working properly :(
    Scholar:
  • 122 Answers
Do you have a drive letter F already on your computer? If so, many USB flash drives try to use that drive letter and do not show up in your "My Computer".
You can go to your disk manager and see if the disk is actually present:
right click on your My Computer icon -> manage
choose Disk management
See if the flash drive is listed. If not, try another USB port - still not? Drive may be bad :-(
If the drive is listed, right click on the square to the left side and choose "change drive letter" Change it to an unused letter, such as "U". Check your My Computer, it will be there
Hope this helps
Posted on Jun 18, 2009
Try going to control panel-->add hardware--> select detect automatically. sometimes windows fails to detect things using p&p
Can't turn on my Argosy HV372T when it's not plugged in my computer
for tvs blueray players you have to have a flashdrive some tvs bluerays will only reed a flashdrive that is 8gb or under
Nov 07, 2012 | Argosy Hv372t 3.5 Usb 2.0 Multimedia...
Flash Drive (Kingmax) cannot be read by the computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no
dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Jul 06, 2012 | Electronics - Others
I have a PNY USB 4GB Flashdrive, and when i plug it in, it shows that it isn't plugged in. I try to look for it, but it shows nothing is plugged in. Please Help!
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
May 13, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
How do I put pictures from my home computer onto the SanDisk?
Once you plug the sandisk into your computer, a window should pop up asking you if you want to view the files on the disk, if it does, click on it. If not, just go to Start Menu -> My Computer -> (The Flash Drive). Move this window to the side so you can see the desktop aswell as the flashdrive folder. (You have have to 'demaximize' (Restore Down) the window so that you can see the desktop aswell. Then go to the start menu again and go to "My Pictures" or wherever your pictures are located. then, you can click and drag the pictures from the "My Pictures" folder into the FlashDrive's folder. Once all the images are copied into the flashdrive folder, you can unplug the flash drive and the images will be on it.
Hope this helped, Nathan Taylor
Jul 21, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hi , My san disk 4gb cruzer micro flash drive has the LED on when i plug it to any computer but doesn't show up on My Computer , Disk management or Device manager . I have tried 3 different desktop...
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
May 30, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to rcover from my sandisk back to my library
1. Does the flash drive LED light up when you plug it into various computers? ( not just your own fortesting purposes).
2. Does it pop up in windows explorer at all? ( Should be labeled as Removable Disk by default)
Your flashdrive may have essentially died. Test this flashdrive on multiple computers to determine whether its your computer or the flash drive. If you are trying to recover information try out the app Recuva which can be found on google search. Your information may have been corrupted.
May 05, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do I download pictures from my computer onto a usb-16gbtr, there are no instructions with the flash drive
Just plug the Flashdrive into the USB port of any Computer and the Operating system ie: Windows should just pick it up with Auto play after a few seconds. Open the FLashdrive under My Computer?Computer(depends on the version on windows you are using) Open the Mass Storage device or the drive that shows the Flashdrives details and then just copy your pictures from the folder which you saved them and then Paste them into the Flash drive.
If you want a more detailed description, just let me know what Windows or Operating sytem is on your Computer or the device you want to download from and also the make and model of the Flashdrive.
Hope this helps
"Even your Computer needs a rest"
www.thecomputerspa.co.nz
Jan 31, 2011 | Computers & Internet
San Disk Micro Cruzer 4GB
Try plugging it in to a different USB port on your computer. Make sure the connecter on the Cruzer is clean and there's no dust inside.
Also, try plugging it in on a different computer.
If none of these work,
I'm afraid it's a hardware problem and there's nothing that can be done about that.
Hope I helped!
Tom
Jun 20, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Malfunction
unfortunately the files cannot be recovered immediately, macs a are compatible with PC flash drives but not the other way around. you need to format the disk. go to start>my computer> then right click on the flash drive and then left click on format, then click ok. when it is done bring the flash drive back to the mac and put the files back on. now try putting the flash drive into the pc again
Jan 23, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
1,891 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
