Question about Xerox Office Equipment & Supplies
Model 3540 this is the second machine, the first one locked up the fax line and we returned it, they replaced the machine and gave us a new one, now we cannot send or receive any faxes, it dials but it sounds like there is no handshake between the machines, I dialled the fax we are trying to send to and it answered and gave a handshake tone. is this a common problem with these machines?
DJYar
  • 41 Answers
SOURCE: wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Posted on Aug 23, 2007
leroyal
  • 2120 Answers
SOURCE: fax will not send
Does the receiving or sending party have a DSL phone line?
Posted on Sep 01, 2008
SOURCE: Fax machine Disconnecting
Toshiba DPBDF
Error Code 60 or Paper Size Error
Help!
Posted on Sep 23, 2008
SOURCE: won't receive faxes
Make sure the receive faxes button is set properly. If it is not set to fax only, you will need to manually receive faxes, the machine will not auto answer.
Posted on Dec 15, 2008
qpoint
  • 69 Answers
SOURCE: i have no dial tone on my fax machine and i cant
Remove the phone line from the back of the fax and connect a standard phone (not a business PABX or PAX system phone) to the line. Ensure dialtone is available. (Make sure in doing this that you are also testing the cable from the phone socket to the fax). If no dialtone, replace cable or fix line.
Check that the line is connected to the 'line' port on the fax, not the 'phone' port.
If still no dial tone, it may be modem fault (in the fax). Seek specialist attention.
Posted on Mar 06, 2010
0x05 epson error code
What us the result of the error? what are you doing to produce the error?
Sounds, offhand, like a driver failure of some kind (ADF??)
Jul 19, 2015 | Epson WorkForceR WF-3540 All-in-One...
Fax machine, Brother IntelliFAX 4100e, is out of memory, what do I do?
unplug machine, hold "stop/exit" button down while plugging machine back in. continue holding button down for minimum 5 seconds, then release and see if display returns to date/time. if so your good to go.
hth,
razors
Sep 20, 2011 | Brother IntelliFAX 4100 Laser Fax
Machine will not pick-up call to receive a fax. have tried all soultions listed in manual
I would have the telephone company check the line to make sure that the wires are not reversed at the wall receptacle for the phone line.
Secondly, if that is not the cause, I would exchange or return the fax machine to where you bought it and see if another unit will receive calls on your line.
Jan 13, 2011 | Toshiba DP-85F Fax
Phone keep initializing
I had the same problem (constant initializing with dropped lines, no dial tone, etc) with my RCA Visys 2-line phone (model 25205) after owning it about 3 months, and could not find a solution on the Web, so I called RCA customer service. They said this problem is not user-fixable and they gave me an RMA# to return it. They will send a replacement phone as soon as you fax the receipt, your name, problem with the phone, etc.. Then when you get the replacement phone you send them the bad phone.
Aug 31, 2010 | RCA ViSYS 2-Line Speakerphone
Cant fax or rec but have line
It would help if you gave make and model...however "generally" if a fax can't send or receive but there is dial tone..what I would do first is call the fax machine from a telephone and see if it attempts to answer( do you get the tones in the earpiece of the calling telephone.??) if not try the machine on another line to eliminate the line...after that you could have an NCU, MODEM or Main PCB fault depending on make and model.
Aug 19, 2010 | Office Equipment & Supplies
Phone company added a dedicated fax line to the outside of my house and my home phone rings to my fax
Your wall outlet has four wires, the center two are the first line and the outside two are the new fax line. You need to go to Radio Shack and get an adapter to split your first and second line into two separate wires. The part number is below.
Steren® 2-Line 4-Conductor Splitter/Adapter (Ivory) pixel.gifModel: T07843 | Catalog #: 55034722
Mar 09, 2010 | Panasonic KX-FHD332 Plain Paper Thermal...
2 fax machines on 1 line
Once you place your both fax machine on same line you will keep getting this issue. Fax machine is waiting for a fax ring signal that your other machine is sending. Shut down one machine when faxing or connect your alt fax machine to a different number this way you can send faxes when need to.
Jun 09, 2009 | RCA 25201RE1 Corded Phone
How to Set up Machine to Receive Faxes
It should work right out of the box.
Plug a regular phone into the wall jack to verify that you have a dial tone.
Is it DSL?
Aug 27, 2008 | Brother MFC-8220 Fax
HP 1040 "JUNK " FAX MACHINE
can hp 1040 fax transfer printed copies to hp pavillion note pad
eadyj1948@yahoo.com
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
16 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
