Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Ice collecting at bottom of freezer
There is water/ice collecting underneath the bottom of the freezer door and is then overflowing onto the floor.
watugot
  • 290 Answers
SOURCE: Water collects and freezes in the bottom of the freezer
Your defrost drain is clogged. Get all the ice out and get to the defrost drain hole at the very rear bottom of the freezer. I use a piece of plastic tubing to run down them and clean them out, but you can use a piece of wire if it doesn't have a sharp end that will damage the tube. You can also remove the rear cover of the fridge and you will see the tube going from the cabinet to the drain pan and clean it from there. Post back if you need further help.
Posted on Oct 20, 2007
kevin000
  • 1847 Answers
SOURCE: JCD2389GT
Go through this link....
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on Aug 12, 2008
SOURCE: JCD2389DES Water Leak Problem
Once I saw that the drain tube went up over the coil before draining into the evaporator pan I decided to buy a small piece of flexible plastic tubing and re-route the tube so the water could freely flow down hill. It's been over two months with no additional problems. I can assume that since the water drains freely it doesn't stay trapped in the elbow freeze and the cause the collector tray to ultimately overflow.
Posted on Nov 24, 2008
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
Water is collecting and freezing on the bottom freezer.. Overflow water is leaking on to floor,
bad door seal resulting in condensation and water leakage. secondly a bad defrost terminator will cause a build up of ice in freezer
Mar 12, 2015 | Whirlpool Refrigerators
We have a new whirlpool refrigerator....there is watering collecting in the bottom of the freezer side and it is running out onto the floor..do we need a repairman or is there something we can adjust to...
Sometimes the drain can clog with ice. If this is it - simple fix. Empty the freezer and find the drain. Put hot water in the drain with a turkey baster or try using a hair dryer to thaw the ice and let the water drain. A small amount of water drainage through this drain is normal. The water sits in a tray underneath and evaporates helped by heat from the compressor. If the drain plugs, the water will build up in the bottom of the freezer and become an ice block.
Feb 25, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Where is the defrost drain
Back behind the metal "wall" at the rear of the freezer, there is a raised "shelf" with the drain in it. Pull our freezer racks or shelves, remove a few screws, renove sheet metal "wall", and you will find it at the bottom there.
Jul 22, 2014 | Maytag Refrigerators
Ge pfs22mis ice maker won't stop
Hello:
No real fix here, just a design flaw..
Try switching ice maker on /off switch until you ready for more ice..
Cheers
Jul 15, 2017 | GE PFS22MIS
Where does the water drain from on a whirlpool ED5FHGXS Ref? The water collects at the bottom of the freezer section and then runs onto the floor
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 16, 2011 | Whirlpool Refrigerators
Water leaking from bottom of freezer side onto floor.
Leo Ponder
imufo2
Sep 15, 2011 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Water in the bottom of the freezer compartment, collects and freezes ,fills the bottom with 1/2 of ice. continues and runs out on the floor. LG LFX25975 Where is the water coming from? Doors and Drawer...
Leo Ponder
imufo2
Sep 03, 2011 | LG LFX25975SW (247 cu ft) Bottom Freezer...
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
If the drain is clogged with Ice or ? it overflows into the ref.
Leo Ponder
imufo2
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Aug 11, 2009 | GE Refrigerators
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
44 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
