Question about Garden
Craftsman hedge trimmer quit working
I hit the fence with it and now when i turn it on all i get is a humming sound with no movement of the blades
Most likely the gear skipped out of position. You have to unscrew the case. Remember or draw the spring position for the handle/switch. Then unscrew 4 screws that attache the blade assembly to the gearbox. Take off the cover (remember the position of the small dent in the cover). you will see where the gear engages the motor worm screw. If you cannot turn the plastig gear shroud, the gears are out of mesh. use a small screwdriver to free the gears from each other. Reassemble, lather, rinse and repeat.
Good luck.
Posted on Sep 15, 2009
  • 154 Answers
There is something jammed between blades or one blade is bent
Posted on Aug 03, 2009
The blades won't move on my black And decker 40 volt hedge trimmers. It sounds like the gears are not turning
How To Repair Jammed Hedge Trimmers - SelfGrowth.com
www.selfgrowth.com > Articles > Spirituality > Self Knowledge
The frequent use of powered hedge trimmers poses the risk of the blades becomingjammed (and it is highly likely that this will happen to your model at least ...
Fixing a Hedge Trimmer - YouTube
? 3:15
https://www.youtube.com/watch?v=aMddbl9B0iE
Jul 23, 2011 - Uploaded by Joby F. Randrup
Ever had a hedge trimmer break because you hit a fence or something ... HEDGE TRIMMER REPAIR "how to sharpen hedge trimmer blades" ...
Nov 04, 2015 | Garden
Hit fence with blade and now it wont move
Without direct exposure to this model, check the parts catalog, there is more than likely some type of coupler between the engine and blade assembly. Usually they are added for exactly this situation. Worse case senerio, the gearbox for the blades is "toast".
Oct 05, 2012 | Poulan Ght225 25cc Gas Hedge Trimmer
Edger blade quit turning on convertible weedwacker
One of 2 things...drive cable broken or clutch spring broken
Sep 10, 2012 | Sears Craftsman Convertible 25cc 2 Cycle...
Electric hedge trimmer only hums when I turn it on. It accidently went through a metal fence. The blade is slilghtly concaved. The hedge trimmer is a black and decker tr1700. I've taken the cover...
look carefully along the teeth of the cutter blades and see if one tooth has not jumped over the opposite tooth thereby locking the blades together
a bent up edge will do the same effect
you can remove the cutter bar and then the cutter bar cams then run the motor
if it still hums , junk it
Oct 07, 2017 | Electric Garden
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
Hi! There is power to the unit....the blades don't move.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Jun 08, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Homelite hedge trimmer , motor runs but blades do
What I did:
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
B&D electric Hedge trimmer I was cutting bushes and hit the chain-link fence. Now, the trimmer just hums. Can it be fixed?
Yes it can but you need to find what jammed. I would check for a bent shaft or a wrapped cable. Good luck
Apr 26, 2010 | Garden
Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Mar 14, 2009 | Black & Decker 22" Electric Hedge Trimmer
Garden Logo
315 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
