PS3 red light flashing, sometimes turn off itself with no reason - Generally it means CPU overheat, but there are also other issues related to it. But don't rush to find someone to fix it yet! You CAN fix it by yourself after you follow my tutorials.
Remember, you are not the only one to suffer this problem! Because I had help so many people to fix the same problem now. You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved many PS3 problems after bought this guide. Not only you can fix the red/yellow light blinking problem, it also contains many PS3 hardware fixing solutions too! The author of the guide is a genius and really kind and helpful to his customers. When you have learned the skills, you can help your friends too! Now go to buy it and share what you have learned !
>> PS3 Completed Fixing Guide <<
Playstation turns itself off and flashes with red light, that's not only indicates CPU overheat - There are many other issues related to it. But don't waste money to find someone to fix it yet! You CAN fix it by yourself after you follow my tutorials. Remember, you are not the only one to suffer this problem! Because I had help so many people to fix the same problem now. You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty! I had solved many PS3 problems after bought this guide. Not only you can fix the red/yellow light blinking problem, it also contains many PS3 hardware fixing solutions too! The author of the guide is a genius and really kind and helpful to his customers. When you have learned the skills, you can help your friends too! Now go to buy it and share what you have learned ! >> PS3 Completed Fixing Guide <<
Does the red light turn yellow at anytime soon?
If so it's a classical case of YLOD (Yellow Light of Death, you can find it all over the internet).
Best thing you can do is contact your Sony PlayStation support department for your country. The number should be listed in the manuals that came with the unit.
ps3 turning itself off can be a power problem try unplugging and replugging all ps3 power cords and extension cord. as for the freezing it could be many things such as certain games fallout series black ops could also be corrupted save data (often gotten from turning console off while saving) make sure you are not getting a yellow light on your ps3 when it turns itself off (the new yellow light of death for ps3 if this does occur you need to get console fixed)
The PS3 Yellow Light is the 360's cousin for the Red Ring of Death. My assumption is that you may have unintentionally blocked any sort of cooling the PS3 has. Here are some steps in correcting that yellow light. This information comes from HowtoFixyourPS3.com:
In order to fix your PS3 yellow light error, there are 3 things that you can do.
1 - Restart your Playstation 3. 2 - Check for loose cables. 3 - Unplug all cables, and plug them back in. 4 - Take out your hard-drive, and place it back in your console.
If these 4 tips didn't fix the PS3 yellow light problem, then it's high likely that there's something wrong with your hardware. In order to repair that problem, you can do 2 things. You either send your console over to Sony. Or, you simply fix the problem yourself while using a PS3 repair guide.
If ur ps3 console wont start up....then the
things to check are>>> 1.check ur power cable 2.check whether u have
inserted the disc properly and precisely. 3.check the insertion of memory
card... 4.check the video port....... The PS3 red light problem occurs when your system refuses to boot up and
has a small flashing red light on the power button. In most cases, the power
button will turn from red to yellow and then back to a blinking red and the
system will not boot up from there as it is supposed to. There can be a variety of issues that cause the Playstation 3 red light
problem, but in most cases it comes down to the system overheating. The more it
overheats the more damage is created internally to the motherboard and other functioning components. This can be caused simply by a flaw in
the system or by obstructions to the fan vent such as a wall, floor, or
excessive collection of dust... click here to download repair guide
maybe its heated cool it down if that does not work tell game stop you bought the ps3 2 weeks ago and then tell them you dont have a reciept if u do have a reciept good
The best way to fix PS3 light turns itself off and won't come back on is to fix by yourself! Learn the PS3 fixing technique by using this product here : PS3 Ultimate Fixing Guide This is a package of text and video tutorials written by a professional PS3 repairman. Follow his demo you can easily to unscrew your console and fix parts inside. When you have learned the repair skills, no need to ask anyone here again!
