Question about Haier RTC1700 1700 Watts Toaster Oven with Convection Cooking
My Haier rtc1700 has no power
I plug my Haie rtc1700
Toaster oven won't turn on...light not on, no heat
check breaker and plug--if power to plug you would need a meter to test the controls and elements for problem
Sep 05, 2016 | Oster Toaster Ovens
Where to get wiring diagram
Not sure where you are but try this link: http://www.haier.com/us/ if you are not in the US you should be able to get to the country you want but the manuals should be the same except the language.
Nov 28, 2014 | Haier RTC1700 1700 Watts Toaster Oven with...
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
My krups stop working while i was heating up food What can be the problem?
Make sure you have AC at the wall-plug by plugging in another appliance there. If not, you may have a tripped GFI (Ground Fault Interrupter). If power is there, a thermal fuse, now common in many 'hot' appliances, may have failed. These are almost all made in China now and have proven very unreliable; you may just be another victim of this.
Feb 16, 2011 | Krups Toaster Ovens
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
Online manual
Go to the link below and type in your model number then it will display your manual
http://www.haieramerica.com/en/support/modelsearch
Aug 21, 2008 | Haier RTO1400SS Toaster Oven with...
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Manual for Haier RTO1400SS
Apr 26, 2008 | Haier RTO1400SS Toaster Oven with...
Haier RTC1700 1700 Watts Toaster Oven with Convection Cooking Logo
29 people viewed this question
Top Haier Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Haier Toaster Oven Expert? Answer questions, earn points and help others
