Question about Vulcan 36" WIDE ELECTRIC(Click Here): WALL MOUNT 36" Kitchen Hood
Can i clean or do i need to replace the filter for a turboair model GR 01N
I am getting a 01n code on display..is this an easy fix?
Yes, it's easy to fix. Turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the air intake filter and clean it. You can vacuum it or wash it. If you wash it, use warm water and dish washing liquid. Rinse and allow it to thoroughly dry before reinstalling it. DO NOT operate the dehumidifier without the filter installed.
The above should take care of the O1N Error Code.
Jun 26, 2011 | LG LHD459EL Dehumidifier
Need service manual and parts book for TurboAir TAS-09
User manuals can be very tricky to get as various models usually have the same details for devices. Best way to get your user manual is to visit the customer support segment of the manufacturing company of your product website. From there check for your specific product and the user manual is most likely to be available for download free. Normally i would do a search for the product and send you the link but i might end up sending a different link.
Hope this solution has been helpful?
Apr 12, 2011 | Turboair Heating & Cooling
Unit aill not turn on.new batterys in thr remote, (second set).Also can this unit be run manualy? My model # is TAS12VW/O
What is the manufacturer of your unit please?
the model # is coming back as invalid.
thanks!
Aug 06, 2010 | Turboair Heating & Cooling
M3 Turboair Refrigerator does not cool
http://www.turboairinc.com/TB-Service/Service.html#SANDWICH
Try this web site. It has you M3 listed with manual but needs exacting model number to get right one.
good Luck - Hope this works for you. If not, let me know.
Jun 27, 2009 | Freezers
Commercial Freezers
I have worked in a lot of kitchens and don't really have a preferance. The top mounted compressor is better for you as it is easier to service and leaves more cabinet room. Dirt and dust also stay near the floor. YOu won't have to clean the filter as often up high The disadvantage to this in a kitchen is that kitchens are hot and up high is hotter still. Order a cheaper model. No glass doors, no stainless steel. You don't need these features.
Jun 24, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Turboair taw-12 missing grate
Try one of these supply companies, they've only failed me a couple of times.
http://www.wilmar.com/
CENTURY Maintenance Supply , 1-800-880-3416
Johnstone Supply, 1-800-493-4822
Maintenance Warehouse 1-800-431-3000
That should get you started. Hope it helps.
Dec 10, 2007 | Turboair TAW-12 Air Conditioner
Head cleaning
As per our live chat - once the heads have been cleaned twice consecutively they are almost certain to be damaged and need service or replacement. The manual in english is here: http://books.jvcservice.com/booklist.asp?Model=gr-d250 Page 44 is very clear on this issue Hope you get a solution from it :)
Mar 28, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Kitchen Ranges Logo
56 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Paul Carew
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
