Question about Electrolux EOB6632 Electric Single Oven
Electrolux gas cooker thermal cut out
Is it okay to bypass the cut out
2 Suggested Answers
  • 3 Answers
SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Posted on Jan 15, 2009
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
Jan 18, 2015 | Kenmore Ovens
Bypass a faulty timer unit on a stoves 720ef cooker. . . . My partner tried this today on my cooker and now there is no power to the cooker at all!! Is there a chance he's managed to do the wr
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Dec 16, 2014 | Stoves 720EF Electric Double Oven
Electrolux EOD5310 Electric Double Oven power to oven but no heat
If you have a problem with your Electrolux EOD5310 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2014 | Electrolux EOD5310 Electric Double Oven
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
Jul 01, 2014 | Electrolux Ovens
I have an Electrolux double oven and grill which has stopped working. The power has gone off and the gas isn't flowing. The electric supply has been tested and is fine. Any clues???
you didn't specify a model but most of the electrolux unit have a single control panel across the top behind the front control panel on the main circuit board is an object about the size of a dime with a small red button in the center apply firm presure to this red button it will click back into place (if that was the problem) its a thermal over load and is sometimes accidential tripped by trying to broil some thing in the top oven with the door open a little bit excess heat gets in behind the controls and pops the thermal WARNING turn off the power before attempting this the reset is mechcanical and does not need power to reset it ALSO lots of delicate stuff in there- ribon cabels -thermal coupling leads be careful
good luck
Sep 05, 2009 | Electrolux Ovens
Electrolux EOG7330 gas cooker - electric timer fails?
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Electrolux Oven EOB6630, similar to above
Hi, I've had a similar problem with my electrolux EOB4633. I've replaced the "thermal cut out unit" and it's working now. Basically this unit switches on the outer casing fan ( on top in my oven ) to keep the casing from overheating. When the thermal cut out doesn't work it fails to switch on the fan and the casing overheats, the oven then cuts out completely until it has cooled down and the cycle starts again.
The bit to be replaced ( part no 8996619267611 ) is located on top of the oven, under the outer cover, just behind the timer & selector switch. It's a small ( 1inch long ) silicon sleeve with 4 wires coming out of it, just unplug the wires and replace it with the new one ( unplug/disconnect the power to the oven, or switch of the power at the mains switch first ), then remove the oven outer top cover ( all you need is a screwdriver ). You'll see the offending unit, probably tie wrapped to one of the wire bundles, quite easily - mine was blackened and charred.
Jan 29, 2008 | Electrolux EOB6636X Ultrafan Electric...
Delonghi DFS901SS
have the same problem as you all. i myself removed the top of the hob to reveal a burnt out control switch . i have looked online for a replacemrnt , and it is £66 plus vat from delonghi but have found a cheaper one for £42, cant remember which site it was but type in cooker name and model on google and you will see it for yourself . good luck to you all, it seems like an easy fix
Mark
Oct 21, 2007 | Ovens
AEGB1180-4 overheating/cutting out
It is not the control unit. Remove oven from housing, switch power off and remove either the top panel or the back of the oven You will see two wires going to a thermal overload cut out, looks likse a round thermostat. Join the 2 wires togther bypassing the toc, it will now work okay
Jul 09, 2007 | AEG B1180-4 Electric Single Oven
Electrolux EOB6632 Electric Single Oven Logo
18 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
