Question about Exercise & Fitness
Life fitness t3i treadmill is reading motor-comm error
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 5 Answers
SOURCE: I have a life fitnes treadmil. The read out says
u would have 2 buy a new motor controller communication board and replace the old 1 its very difficult
Posted on Jan 27, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
Life Fitness 9500HR Console Reads Motor Command Error and the Red Led #1 is not flashing.
motor controller board has error comunicating with console, you can try to disconnect all leads connecting to console and reseat. failing that you would need to send off board for repair as new motor controller for next gen model is 700 gbp.
May 30, 2014 | Life Fitness 9100 Next Generation...
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
Treadmill read module comm error
unplug and re plug all connectors and test
Oct 25, 2013 | Life Fitness 95Te Treadmill
Bad Controller Comm Error. I swapped out Controller but still get same error, any suggestions?
i recommend to replace the control board. This is very critical matter for the electronic machine. see the diagram attached, How the controller motor hast the 80 of control of machine.
go to www.fitnessrepairparts.com and get it
Sep 23, 2013 | Life Fitness LifeFitness 9500HR Treadmill...
Hello im getting a startup error when i press the quickstart button on my 95ti treadmill.
when I start up my treadmilll across the screens reads Motor-comm error. what coulld be the problem.I keep it clean and dirt free.
May 03, 2011 | Life Fitness 95Ti Treadmill 95 Ti
Error message notify maintennce motor controller comm bad
Every time I have gotten this message, I have had to replace the motor controller.
Mar 16, 2010 | Life Fitness 9500HR Next Generation...
Hi have life fitness 9500hr.when i opne MOTER
Feb 27, 2010 | Life Fitness 9500HR Next Generation...
On display stands: MOTOR COMM BAD
Try Carolina Technical Services in South Carolina for all you East Coast guys. They charge flat rate of $175.00 and have a 90-day warranty. Also great turnaround time. Carolinatechnicalservice.com. 864-504-7303. Sure beats sending to California and having to wait for 3 weeks.
Jan 29, 2010 | Life Fitness 9500HR Next Generation...
Jan 23, 2010 | Life Fitness 9100 Next Generation...
Exercise & Fitness Logo
51 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
