Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
LT 1000 flooding gas out muffler and stalls, then pours in carb.
It was smoking real bad when cranked and flooding out. When it stalls the carb. floads with gas. Can you help???
  • 376 Answers
Check your oil. Does it smell like gas? If so, don't run it even if you could. You will fry your engine. The float needle and seat in the carb are leaking. In other words, the float needle is not shutting off the gas when the bowl is full. You need to have them replaced.
Posted on Jun 18, 2009
Air filter fills up with dirty gas
Sounds like the float in the carb is stuck open or has a hole in it so it won't work.
Sep 18, 2014 | Garden
Gas pours out of carb and muffler
float could be ok but the needle and seat or bad replace them
Aug 16, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Flooding carb
carb float is sticking,clean bowl good
Oct 12, 2017 | Yamaha RD 350 Motorcycles
Husqvarna riding mower seems to be flooding.
rebuild the carb and change the oil a couple times
Mar 21, 2012 | Husqvarna Garden
Engine stalled out,would not start, pour gas in carb,cranks,keeps running,until idle falls below 12to1500rpm,than stalls out again and will not crank,repeat gas or starting fluid in carb,cranks runs and...
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
Dec 27, 2010 | 1993 Chevrolet C1500
After changing a blade on my viking mower, it no longer starts, is there oil in the air filter? how do i fix this ? Thanks
It sounds like you tilted the mower in the wrong directions when changing the blade. If you tilt it with the spark plug pointing down insead of up, this alows the oil in the crankcase to enter the head and then it bleeds past the intake valve and or exhaust valve where oil then gets in the carb./ air filter or muffler. Pull the spark plug out and inspect, it may be covered with oil killing the fire. Check your oil level, replace your air filter, try to start. It may smoke real bad for awhile. It should clear up after getting hot and burning it out of the muffler.
Dec 04, 2010 | Garden
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Rough idle, condensation comes from tailpipe when cranked. black smoke, and carb.floods with gas . seems to quit when its gets warmed up and then sometimes it dont.
I don't know the year model, if older carb, sounds like stuck choke, bad choke pull off or bad needle and seat in carb. If newer model, computer staying in closed loop, bad temperature sensor.
Feb 12, 2010 | Toyota Pickup Cars & Trucks
Will start but then stalls and then gas pours out the air filter
float needle probly has some foreing piece of something stuck in it ,, allowing too much fuel in the carb,which floods out the engine
Apr 13, 2009 | kawasaki EN 500 Vulcan Motorcycles
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
643 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
