Samsung KF-35G/FWD Remote code needed
Hi. I have a DL Air conditioning split system with a AR1731 Universal A-C Remote. The model air conditioning DL DSR-35G/E I am looking for code for the universal remote please.can you...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 17, 2014 | Televison & Video
How to get activation code
We recommend you contact Motorola Solutions.
portal motorolasolutions com
Mark
Motorola Mobility Support
Aug 05, 2014 | Zebra MC75A Premium 35G Worldwide...
Disassemble youtube LGL 35G
It must be in the manual. I can't find the manual from the 35G, but the LGE400. There you have to remove the back side if the phone, before you can place / remove the sim and or memory card. Read the manual carefully because if you place the card the wrong way around, you will damage the card and the phone.
Please next time place in the correct category.
Nov 23, 2013 | Cameras
Remote code for lg kf20p30
i need remote contol for LG, model : kf-
20P30
Aug 27, 2013 | LG Televison & Video
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
I need help programing my rca remote to a samsung television
Hi
Ideally I need you to clarify a few details on your exact RCA remote model and number and also whether this is a Samsung TV or other unit like a DVD etc.... that you wish to program
However assuming it is a Samsung TV here is a list of the common RCA codes for this TV. You will need to go through each one individually until you find one that works.
Code 1004 for Samsung TV Code 1005 for Samsung TV Code 1006 for Samsung TV Code 1012 for Samsung TV Code 1013 for Samsung TV Code 1015 for Samsung TV Code 1017 for Samsung TV Code 1019 for Samsung TV Code 1082 for Samsung TV Code 1104 for Samsung TV Code 1105 for Samsung TV Code 1106 for Samsung TV Code 1171 for Samsung TV Code 1172 for Samsung TV
Hope this helps. If so please do rate my answer.
Otherwise please post up additional details as outlined and I will see what I can find.
Many Thanks.
Sep 06, 2009 | RCA ACC-RCAURC Remote Control
I have a Sony tv kf-50we610 and a Jumbo Universal Remote by Innovage Products. I need programming codes.
Ok here it is.. I am giving you 2 links:
Sony remote control page 87 (this is the direct pdf): http://www.docs.sony.com/release/KF50WE610.pdf
Your Jumbo remote by Innovage Products:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other (this site downloads automatically prompting you to accept and save to your hard drive)
f2d52b0.jpgDon't forget to rate!!
Jan 03, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I will unlock regional code philips PET 835/00 The regional code is 2, I NEED MULTI ZONA.
try this :
select DVD mode
on the unit push PLAY
with the remote press 1 4 0 0
a menu appears
select region
press FWD to change the region code until 0 for codefree
press MENU to exit
Best regards.
Sandro
Nov 30, 2008 | Televison & Video
Sony KF-60WE610 TV remote is acting up. Remote tests fine. DVR is also new, so that isn't the problem either. First noticed volume would not go up and down with DVR remote, but TV remote OK. Then wouldn't...
Hey Bry,
Judging by the picture of your television on Sony's site: http://esupport.sony.com/US/perl/model-home.pl?mdl=KF60WE610&LOC=3
The IR sensor is right below the Sony emblem. If you're really curious you can find a site that offers service manuals and order one. It will get you schematics and tell you exactly where everything is.
Also, if you get everything up and running and decide you need to replace your lamp, check out xl2100u-lamp.com. I haven't ordered from there yet, but it looks promising.
Jun 27, 2008 | Sony XL-2100U Projector Lamp for...
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
