Question about JVC Everio GZ-MG21 Camcorder
While recording there is noise distortion
On some recordings there is noise distortion
2 Suggested Answers
  • 321 Answers
SOURCE: Recording in places with lots of noise, causes
hi,may be your camera needs a good clean up off the head
system before ,or its could be the soud setting or the mic its self
hope that will help
regards alan
Posted on Oct 06, 2010
Static Noise
Is it a hissing noise or a distorted crackling noise? If it's a hissing noise then it's due to a bug in Windows that adds 30 dB of gain. It's easy to work around, though: Go into Recording devices, Properties button, Levels tab, right click on the level number so that it shows in decibels, and then adjust the level to 0 dB. It's supposed to be at 0 dB but Windows 7 defaults it to 30 dB for no reason. This isn't a problem on Windows XP or OS X.
Jan 04, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
Hello, i am having noise problems when i recording with my zoom h4 in mp3 format, the funny thing is that every thing is ok when i record in wav format, do you have any idea about what could be the...
MP3 is a compressed format so there MAY be some SLIGHT distortion in MP3. It should not be a significant level however. I would contact Zoom and get support from them regarding this problem.
Mar 10, 2011 | Samson Technology Zoom H4n Handy Recorder
Recorded acoustic guitar is fuzzy and distorted
Try anouther Microphone sounds like the frequence sprecturm is to low.
Jul 09, 2009 | Samson C01U USB Condenser Microphone...
Sound very distorted
This turntable has a preamp switch on it, which is probably on and what is causing the distortion. Take off the metal record platter by lifting up on the two holes gently. Turn the pre-amp switch to 'off' and then try it again. This is probably it...
Or you can plug it into an input that doesn't have a preamp and that should work.
Dec 25, 2008 | Audio Technica AT-PL50 Turntable
Distortion when recording flute on cubase
K, 1st of all... Try listening to the files directly from the h4, before download to the nbook. No dist? Problem solved.
Otherwise, note the mics are really sensitive, even in low gain, any "wind" instrument, like your flute, my clarinet, or even the voice can generate distortion.
solutions:
1. You have a "monitor" mode in the h4, just check for it, easy to find. Then you can adjust details on the h4, as you play and listen the output.
2.check the distance you are playing from the mic, be generous with that, anyhow you can move higher the gain. :)
3. Don't play directly to the mic, as the air from your instrument may generate a noise that is not a note, but simply air coming through the mic.
Monitor through computer... I'm stucked trying to make it work with any recording program in Vista, don't know how to make the system rcognize the device.So, I can't help you, and by the way, do you know how to record in Windows??
Luck bro
Jun 17, 2008 | Zoom H4 Handy Recorder
Distorted Image
if it records the distortion then i suspect the guides are out of adjustment or your capstand roller is pushing the tape to high on the guides. need to have a profession serviced.
Feb 07, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
DISTORTION
1) if you are using the PC sound card to record this is where your hiss is coming from. you need to get a recording card that has low noise or some other recording USB input device to get CD quality recordings
OR
2) if you have to use your PC sound card check your PC volume level for line in, don't let it get high or it will distort. you will have to experiment with the MD4 levels and PC sound card level to find a good middle ground with low hiss and no distortion
and a singer that sings away from the mic to reduce distortion.
hope this helps
thanks for your rating
Jan 09, 2008 | Shure SM87 Professional Microphone
Very bad recording
Be sure you are in the SP record mode and use the dictate conferance setting depending on your environment.
Oct 06, 2007 | Olympus DS-2300 Digital Voice Recorder
JVC Everio GZ-MG21 Camcorder Logo
21 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
