Question about Stihl Garden
Ht 131 shaft keeps slipping out of cutting head
  • Stihl Master
  • 1,807 Answers
Make sure the gear hed is engaged on both the outer shaft and drive shaft at both engine and cutting head end. Check the square drive section that is in the plactic moulding hasnt been pushed too far into the shaft meaning its not engaging properly.
Ht 131 shaft keeps slipping out of cutting head - 24138579-43aifetetdbkhmxjhl5awpdp-1-0.jpg
Posted on Mar 07, 2015
The 131 chain stops when cutting
Rev,s to high at idle.engage chain brake if fitted.
Oct 01, 2016 | Garden
The head on my Bolens BL110 weed eater is slipping
Check the drive shaft. Within the drive tube there is a tightly sprung drive shaft, check where this connects to the head of the cutting attachment, it could have a worn drive.
Apr 10, 2016 | Garden
Stihl pole saw model HT75--Was cutting a limb and the chain stopped cutting--What is the problem?
Could be a few things.
1. Clutch slipping at engine end.
2. Drive shafts have become detached from drive or broken.
3. Clutch behind the drive sprocket on the cutting head may need tightening.
4. Chain too sharp/aggressive and is trying to cut too much and the stopping the chain.
5. Chain too tight.
Nov 11, 2015 | Stihl Garden
Hi I've Just been given an Inventek Spiral Saw Kit second hand does anyone know where I can get a manual?
You can view and download the manual from this link . but be sure of your model number first .
May 15, 2015 | Garden
Ht 131 chain does not engage
More information please. Where will the cain not engage in the bar sprocket or on the drive sprocket
Mar 25, 2013 | Stihl Hl Ht Km 87 90 95 100 101 110 130...
How do you keep the shaft from turning when working on it
If you're refering to working on the cutting head without the shaft turning then you should be able to lock the cutting head to remove it. There is a small hole in the top of the gear head that you need to put a small rod in to jam the head from turning.. this inturn will also stop the drive shaft from turning.
Sep 03, 2012 | Husqvarna 28cc Gas Line Trimmer
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Nov 18, 2011 | Tally Matrix T2280 Printer
Hardware alarm 0036 131 000004 0376 0009 hardware alarm 0025 131 000004 0376 0009 hardware alarm 0024 131 000004 0376 0009
Hi, the printer seems to have a problem with the horizontal movement of the print head carriage. Turn of the printer and move the carriage by hand to check if there is an area where it can only be moved too hard. If yes, clean the carriage shaft from dirt, etc.
Sep 08, 2010 | TallyGenicom 2265+ Matrix Printer
The head on the trimmer is stripped out and I couldn't get it off
measure the outside of the tube and any compatible head will clamp on the tube
all internal drive shaft and cables use a 1/4 square drive at the end which slips into the bevel drive gear in the head
normally straight shaft tubes are bigger in diameter than bent shafts
junk yards or dumps are a good place to get heads complete
Jun 27, 2017 | McCulloch Trimmer Plus Attachment: Add On...
Garden Logo
178 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
