Question about KitchenAid KESC307 Electric Kitchen Range
Ran self clean now there is no power to the digital panel gas burners work fine.
aborcass
  • 2651 Answers
SOURCE: KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Posted on Feb 24, 2008
  • 2318 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
Posted on Apr 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: Door locked: display panel not lit.
Unplug the appliance and the next day it will work again. Do not use the self clean cycle or I will have to spank you! Did you not know that 900 degrees for 3 hours can harm delicate expensive electronics. Get some easy off and clean that oven or get ready to spend some serious dough on fixing this puppy down the line.
Posted on Apr 10, 2009
solasknows
  • 199 Answers
SOURCE: Control panel black -No display
no reset fuse inside, by the power cord, also lcd display might be gone hope i helped
Posted on Jul 20, 2009
Frigidaire gas range one burner will not light
Hello Roy Gaudette - If you only have an issue with one burner lighting, then you might have a clogged valve. This is not something you should clean on your own if you have never done this before. I would contact a professional or your manufacturer first. You could also have a blocked or bad valve which would require a full repair service call.
Nov 25, 2012 | Frigidaire Gallery 30" Self-Cleaning...
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Jul 20, 2009 | KitchenAid KGST307 Gas Kitchen Range
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Apr 10, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
No power display after self-cleaning
There is a high limit thermostat that frequently fails when using self clean.
Check continuity on the thermostst first.
Mar 15, 2009 | Whirlpool 30" Self-Cleaning Slide-In Gas...
Amana oven not working and boiler also
Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler.
Dec 21, 2007 | Amana RanARG7302 Gas Kitchen Range
After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
Dec 22, 2006 | GE Profile JGS968 Gas Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
15 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
