Question about Bosch SDS - max Demolition Hammer 11316EVS
How to repair bosh 11316evs
Not working right
    Sergeant:
  • Bosch Expert
  • 206 Answers
Purchase a service kit # 1-617-000-190
This will have all the normal wear parts including brushes & new grease.
This is a fairly easy hammer to rebuild - make sure you thoroughly clean all the parts, install new rings & grease - the kit comes with a parts breakdown to help. Service Pack 1617000190 for Bosch Power Tool eReplacement Parts
Posted on Mar 13, 2015
Do Bosh washing machines have the issue of water pressure? can I get someone senior technical person in the Bosh office who can answer my question?
Look up the senior officers of Bosch and contact them directly regarding your question. (I believe the corporate offices are in Europe--contacting the US offices yielded nothing.) A few years ago I did this when experiencing Bosch dishwasher issues not being repaired while covered under warranty. After contacting the CEO, we got a new replacement.
Jan 16, 2017 | Washing Machines
Which parts need to be greased before I put it back together
Bosch 11316evs a hammer where are complete maintenancekits for with the right grease beware of the parts that are have high priority to observe ALLWAYS REPLACE POS 41 and 39 together to get the neccesary pneumatic vaccuum for the mechanism because if there is leakage of oilseals the o-rings are to early getting HOT and harden prematurely again. also
Also note that the statorfield is mounted with two screws, because it does happen often that these 2 screws are not used!! and this in order to prevent the mangle with the four sliding contacts
A nice old model hammer GBH 11 in the Netherlands and or the same as this new product
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
but finally this is what you are looking for your hammer .!!!
POS 898 partnumber 1.617.000.190 a consumables kit
http://www.powertools-aftersalesservice.com/public/boschprof/service?p_auth=aR4sBRMv&p_p_auth=WUDGLa1r&p_p_id=WSRP_bc93764e__6873__4b00__9a29__b331c9759da9&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&_WSRP_bc93764e__6873__4b00__9a29__b331c9759da9_wsrp-navigationalState=L0JPUy9QVEFTLVBULVNJUy1TaXRlL25sX05MLy0vRVVSL1ZpZXdQcm9kdWN0LURpc3BhdGNoO3BnaWQ9YmI5NWI3MGRjM2E3NzQxY2ExYzA0OGYyM2IzMF9fNDlzR3JsO3NpZD1QMzhKeVRtclkxWndER19mQlhFVk1qWWdLYlM2S19Dd3BYNktZcnNMOW1TVHlMb0F2ZDg9
May 16, 2015 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Bosch 11316EVS demolition Hammer soft start not working. Starts at full speed and does not impact until slowed down.
Variable speed control module has failed, however you can still use the tool. Hammering action will improve with a good cleaning of internal parts and apply new grease. Hammering action is caused by air/vacuum cushion between drive piston and driven piston which inturn hits a third piston that actually impacts the bit. If third piston is worn, chipped and lodged with debris, there will be light hammering action. After use, store the hammer with the nose pointing down so that the driven piston will slide to end of cylinder and ready for next use.
Sep 27, 2011 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Bosch 11316EVS doesn't star. Power cable is good What another issue is possible?
most common problems with these units is brush replacement, or even the on/off switch, I work for a home depot tool rental and are constantly replacing the brushes.
Oct 09, 2010 | Bosch 11316evs Elec Vs Sdsmax Demolition...
My bosh exxcel disher dose dot fill
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Dishwashers
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SDS - max Demolition Hammer 11316EVS Logo
892 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
