Question about Motorola Mobility Endeavor HX1 Bluetooth Headset
Unable to charge motorola endeavor HX1 blueetooth headset
  • Official Brand Answer
  • 1,623 Answers
Is it on or off while charging?
Have you tried another charger?
Mark
Motorola Support
Posted on Feb 08, 2015
2 Suggested Answers
  • 277 Answers
SOURCE: Cannot hear or be heard on motorola endeavor HX1
I suggest you delete this out of your phone and then re-pair it with your phone.
Posted on Mar 02, 2011
My Bose Bluetooth will not charge. It was working great last week. It just stopped charging.
Hello Janine Land,
I would like to recommend you to try a factory reset: with the headset turned on, press and hold both Volume buttons and Call button for 10 seconds until the indicator light is steady blue. Have you tried with different charger?
If not able to turn ON with another charger and not able to perform the factory reset, then the only option will be to replace the device.
Regards,
Lester S.
Motorola support
Oct 29, 2014 | Motorola Mobility Hx1 Bluetooth...
Cannot charge HX1 headset
Try a different charger.
Mark
Motorola Support
Apr 15, 2014 | Motorola Mobility Endeavor HX1 Bluetooth...
I have a motorola blue tooth and I need to pair it to my htc evo.... How can I do that?
Ok, I'll give you a default procedure to put a blueetooth headset in pairing mode: starting with it turned off, press and hold the call button as if you were turning it on, but keep pressing the button until the indicator light is either steadily lit, or flashing rapidly, sometime in more than one color. This is usually achieved by holding the button down for some 6 to 10 seconds. Then, make your phone's blueetooth application search for new devices. After a while, your headset should appear on-screen. Make the application connect to it. If a pairing code (or passkey, or PIN), is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash some times, and enter the stand-by mode (normally flashing every couple of seconds). Your phone should also indicate that a headset is connected. However if the pairing process fails, after a couple of minutes your headset will quit the pairing mode, Turn it off, by pressing the button until the light goes off, and start the whole process again, firstly trying '0000' one more time, then changing it either by '1234' or '8888',
Hope you are able to sort your problems out soon, but, please, let me know if you further assistance.
Regards, Carlos
Sep 14, 2010 | Motorola Mobility Bluetooth Hands Free...
UNABLE TO PAIR WITH MOTOROLA H350
0000 is the default passkey for the Motorola headset
Jan 14, 2010 | Motorola Mobility H350 Wireless Headset
Pairing my motorola H710 to my Blackberry Storm phone
try and remove the current bluetooth device. Close the headset. Go to thephone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Dec 30, 2008 | Motorola Mobility H710 Bluetooth Headset
Bluetooth snyc problem
I'm going to find my solution somewhere else (probably the manufacturer) b/c they won't charge me $10 to get useless advice from a bunch of amateurs.
May 26, 2008 | OEM Systems Motorola Bluetooth Headset...
Can't connecto to headset again...
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
May 09, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola HS850
THE MIKE IS AN ON OFf SWITCH WHEN IT WEARS OUT IT CAUSES THE PROBLEMS YOU HAVE DESCRIBED.
best fix is to get new unit GO WWW.N1wireless.com to get one cheap
Dec 11, 2006 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility Endeavor HX1 Bluetooth Headset Logo
52 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
