Question about Frigidaire FRT21P5A Top Freezer Refrigerator
I keep finding water at the bottom under the drawers
I do not have a icemaker and there bottles of water leeking
  • 111 Answers
In the compressor compartment theres a tube white its blocked jus clean or blow on it
Posted on Jun 18, 2009
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
Water running down inside refrigerator into bottom veg drawer
What you have is a clogged defrost drain. Instead of the water going under the machine it is running down the backside of the wall. If ice is blocking the drain then after that is cleared yall can run a small wire off the heater and down into the hole to keep ice from forming at the drain hole:
Ice box service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2011 | Whirlpool 21.7 cu. ft. Top Freezer...
I have icicles all over my freezer. They started on the door under the ice maker. It is making ice but it won't come out because it the turning thing can't turn because there is solid ice in the bottom of...
Your icemaker is surely at fault. Shut the water off at the valve, turn off the icemaker, and defrost again. Does it happen again? If not, check your icemaker assembly for leaks or replace the water inlet valve if necessary. Good luck.
Apr 24, 2011 | Refrigerators
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
My freezer seems to be accumulating water under the drawer. it is coming from the back wall on the right, but there is no leak anywhere else. I do not have an automatic icemaker installed. What could be...
Plastic water bottles on upper shelves sometimes have small leaks. Remove all above water containers. Maybe you spill some water replacing ice trays? Identify the source of water..that will be the cause of problem.
Feb 16, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Kenmore Coldspot #106.9750610. Icemaker does not
restricted water flow or pressure from house water where your taped into. your shut off or Tap a line may be cloged or if you have a water filter its cloged. It could also be a bad water valve in rear of refrig. start at the sourse of water and work back to frig. A rare thing could be that the timing gear on the ice maker is burnt and not trigering valve long enough to fill icemaker
Oct 30, 2009 | Refrigerators
Freezer is leeking water into the bottom of it ,
I had the same problem.
This is how I solved it.
Remove the bottom drawer of the freezer. There was a lot of ice built up.
I chiseled it out, and then looked in the back.
There is a drain hole that was blocked by a fallen popsicle that melted, and then the plastic wrapper plugged the hole.
Check that the hole is not blocked.
Also, it is always a good idea to remove the bottom black vent cover under the fridge and clean out any dust build up with a vacuum.
Good luck.
Oct 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My refrigerator started leaking underneath on the right back side. Can you tell me what is wrong and what needs to be done?
If you have icemaker in your fridge - remove cover on the back and down and check the plastic water tubing for cracks and loose connections.
If nothing found or you don't have icemaker - there is a drain pan on the bottom, behind the same back cover. Check if it has any cracks or tilted. Check if the drain tube is routed to the drain pan and is securely attached to the drain port on the bottom of the fridge.
Oct 12, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
GE with top freezer has water accumulating in bottom of frig under the crisper drawers.
Remove the food from the freezer , then remove the icemaker , if it has one ( 2 screws ) . Remove the rear freezer panel . Useing a hair dryer , start in the middle of the drain trough , and defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water will go thru . Use a piece of tubing inserted into the hole , and blow thru , to remove any debris accumulated in drain line .Remove any excess ice from trough . Reassemble freezer .
Aug 27, 2009 | GE Refrigerators
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Frigidaire FRT21P5A Top Freezer Refrigerator Logo
191 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
