Question about PaceMaster Exercise & Fitness
Speed sensor located pacemaster
Error 307
4 Suggested Answers
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: Getting a dead sensor reading on pacemaster pro plus treadmill
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Posted on Mar 02, 2010
ercupa190
  • 12223 Answers
SOURCE: PaceMaster ProSelect Error Code 31
mean defective lower PCA or upper PCA, try to tight any plug or connector or ribbon cable, However RUN the software calibration for easy troubleshooting , and fix it.
Go under the hood motor, and follow the step how to enter in the s. calibration.,see the block diagram attached.
God bless you
Posted on Nov 13, 2012
Need to find fuse control for ford five hundred 2004 cruise control
Do you mean 2005 ? Didn't have five hundred in 2004 !
Speed Control The speed control system consists of the following components:
  • speed control switches
  • speed control deactivator switch
  • speed control indicator
  • powertrain control module (PCM)
  • electronically controlled throttle body
  • clockspring
The speed control system is controlled by the powertrain control module (PCM). The speed control system is designed to maintain a selected vehicle speed between 48 and 200 km/h (30 and 124 mph). The speed control system is controlled by the steering wheel mounted switches (ON, OFF, SET+, SET-, CANCEL, and RESUME), and the brake pedal. The steering wheel mounted switches are hardwired to the PCM.
The speed control functions include:
  • turn the speed control system on
  • set and maintain the desired vehicle speed
  • accelerate the vehicle speed
  • decelerate the vehicle speed
  • resume the prior vehicle speed
  • turn off the vehicle speed control system
  • cancel the speed control
  • Smart junction box (SJB) fuse 18 (10A
  • Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action P0579 Cruise Control Multifunction Input A Circuit Range/Performance PCM Go To Pinpoint Test C . P0581 Cruise Control Multifunction Circuit High PCM Go To Pinpoint Test C . P0720 Output Shaft Speed Circuit Fault PCM REFER to Section 307-01A or Section 307-01B . P0721 Output Shaft Speed Circuit Fault PCM REFER to Section 307-01A or Section 307-01B . P1500 Vehicle Speed Error PCM REFER to Section 307-01A or Section 307-01B . P1501 Vehicle Speed Error PCM REFER to Section 307-01A or Section 307-01B . P1572 Brake On/Off Failure PCM Go To Pinpoint Test B . P1703 Brake On/Off Failure PCM Go To Pinpoint Test B . Highly doubt a fuse problem . Take it to a qualified repair shop.
Jul 18, 2017 | Ford Cars & Trucks
How to fix cruise control on a 2006 ford freestar, does not work at all, wont turn on
Note the diagram, at least check the fuse. Check trouble codes, related to cruise control. to check codes yourself, at least, you need an obd2 code reader that will read po codes as well as manufacturer specific codes. It is worth the investment, in my opinion. Make sure the brake lites work.
Mar 05, 2017 | Ford Cars & Trucks
2007 Ford five hundred cruise control turns off when you hit a bump
First off the cruise control is computer controlled , need to check for diagnostic trouble code's . Your vehicle has electronic throttle control also . If your don't have a factory or professional grade scan tool your odds of being able to fix this yourself is close to zero ! You could find a wiring diagram an do some voltage drop testing ,mite find lose connection .
Speed Control
  • Speed control switches
  • Speed control deactivator switch
  • Speed control indicator
  • Powertrain control module (PCM)
  • Electronically controlled throttle body
  • Clockspring
The speed control system is controlled by the PCM. The speed control system is designed to maintain a selected vehicle speed between 48 and 200 km/h (30 and 124 mph). The speed control system is controlled by the steering wheel mounted switches (ON, OFF, SET+, SET-, CANCEL, and RESUME), and the brake pedal. The steering wheel mounted switches are hardwired to the PCM.
  • Turning the speed control system on.
  • Setting and maintaining the desired vehicle speed.
  • Accelerating the vehicle speed.
  • Decelerating the vehicle speed.
  • Resuming the prior vehicle speed.
  • Turning the vehicle speed control system off.
  • Canceling the speed control.
The clockspring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
The inputs to the PCM are:
  • Output shaft speed (OSS) sensor
  • Stoplamp switch
  • SJB messages
The outputs of the PCM for the speed control system are:
  • Speed control indicator lamp
  • Throttle command
The throttle position is completely controlled by the PCM through the electronically controlled throttle body. Speed control electronics are contained entirely within the PCM.
When the speed control system is active, the PCM corrects for deviations in the actual vehicle speed by proportionally moving the throttle plate. The PCM modulates the throttle to minimize error between actual vehicle speed and the desired speed.
The PCM strategy uses the throttle control for smooth accelerations.
The PCM sends a serial message over the controller area network (CAN) to the instrument cluster whenever the speed control telltale should be turned on or off.
In the event of an OFF command or a deactivation request from the deactivator switch, the speed control system carries out a hard deactivation and immediately returns the throttle to the idle position.
In the event of a CANCEL command input, the system deactivates and the throttle returns to the idle position at a smooth and controlled rate.
The speed control system provides self-diagnostics. The speed control system is disabled anytime an error is detected in the system. No cluster telltale or message center messages are displayed when faults occur. Fault codes are logged by the PCM.
An electronic throttle control (ETC) system fault also causes the speed control system to be disabled. In this case, an ETC system warning indicator or message center message is displayed.
Additionally, the following conditions cause the speed control system to deactivate:
  • Transmission gear selector is put into a position other than D or OD.
  • Parking brake is applied.
  • Speed control set speed is over-ridden with the accelerator pedal for a period longer than 5 minutes.
  • Vehicle speed loss from set speed of greater than 16 km/h (10 mph) occurs.
  • Vehicle speed falls below the minimum allowable limit of 48 km/h (30 mph).
  • Speed control switch is pressed or stuck longer than 2 minutes.
  • Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index DTC Description Action P0579 Cruise Control Multifunction Input A Circuit Range/Performance Go To Pinpoint Test C . P0581 Cruise Control Multifunction Circuit High Go To Pinpoint Test C . P0720 Output Speed Sensor Circuit REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual. P0721 Output Speed Sensor Circuit Range/Performance REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual. P1500 Vehicle Speed Error REFER to Section 307-01A or Section 307-01B . P1501 Vehicle Speed Error REFER to Section 307-01A or Section 307-01B . P1703 Brake On/Off Failure Go To Pinpoint Test B .
    Transmission Control Module (TCM) Diagnostic Trouble Code (DTC) Index DTC Description Action P0720 Output Speed Sensor Circuit REFER to Section 307-01A . P0721 Output Speed Sensor Circuit Range/Performance REFER to Section 307-01A .
Mar 04, 2016 | 2007 Ford Five Hundred Limited Sedan
I have a PaceMaster Pro treadmill. I'm getting a dead sensor error message. Where is the RPM sensor on this treadmill? And how do you replace it?
It would be easier to help if I knew the exact model of the treadmill. Here is a link to what a speed sensor looks like.
http://www.treadmilldoctor.com/speed-sensor
You will most likely have to remove the cover on the bottom part of your treadmill to see it.
Aug 17, 2014 | Exercise & Fitness
ERROR CODE P0341, P0609, P0571
EOBD Codes:
  • P0341 - Cam Position Sensor signal error- check wiring.connector,bolted securely. Or sensor itself damaged.
  • P0571 - brake switch wiring or ECM problem
  • P0609 - VSS-vehicle speed sensor output -ECM problem if wiring is OK.
Apr 04, 2014 | 2005 Peugeot 307 1.4
Pace master 870x error code 3 ?
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire isnot working change the magnetic wire or reset the magnet.
God bless you
Jan 31, 2013 | PaceMaster Exercise & Fitness
Mar 02, 2010 | Exercise & Fitness
Exercise & Fitness Logo
115 people viewed this question
Top PaceMaster Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
