Question about KitchenAid Refrigerators
Ice maker ejector blades
Hey, I have a quick question about my kitchenaid ice maker. I've checked it a couple of times, and it is making ice. The problem that I have is the ejector blades. So after the ice is made, and the mold for the ice heats up, the ejector blades are supposed to rotate to push out the ice. My problem is that my ejector blades do move to the up position, but they aren't turning at all after that. So my ice maker makes the ice, then melts it. Should I buy a new motor?
SOURCE: Whirlpool Side by Side Ice Maker Not Making Ice
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
Posted on Jul 31, 2008
ginko
  • 19396 Answers
SOURCE: ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
  • 8 Answers
SOURCE: My ice maker has stopped making ice. I have
Could be the solenoid valve. It is usually located where the water line connects to the frig. The valve may have trash in it.
Posted on Mar 04, 2009
Maytag317
  • 1136 Answers
SOURCE: ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
Posted on Jul 12, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
HI, I have a KSRL25FRSS00 side by side. The icemaker fills with water and freezes, but doesn't dump the ice cubes. I've used a hair dryer on it to melt the ice a little and have got it to dump the...
There is a heater in the ice tray that is supposed to thaw the cubes a little bit so they don't stick to the edge of the tray. When the heater does not work the ice sticks and the motor wont dump them out. You can see more info and comments and how to here: http://www.appliancepartspros.com/repair-help/kitchenaid-refrigerator-ksrl25frss00-repair/ksrl25frss00-ice-maker-wont-dispense-ice.html
Jul 28, 2017 | KitchenAid Superba KSRG25FK Side by Side...
KUIC15PLTS ice maker keeps making Ice even though it is FULL
The high level sensor can get iced up and stop working. using a hare dryer carefully heat the area that the lensing arm goes into or snap off the front cover of the ice maker and blow warm air in there. raise and loser the arm at the same time. a couple of minutes should do it.
Apr 19, 2011 | Kitchenaid KUIC15PLTS 15 Inch Wide 25lb...
Ice maker not filling...already turned off ref let set for 3 hours to thaw still not working
Noticed you did not list your model number of
your Kitchenaid Refrigerator. I see a model number KSRD22FKST above your post
is that correct? If yes there are a couple things that may be causing this. If
the ice maker mold/tray is
full of ice and will not
cycle most times the ice maker thermostat Click Here=> KSRD22FKST while there look at item number
27 in photo. That is your ice maker's thermostat that tells the ice maker when
ready to cycle and fill with water again. The part Number is=> 627985
they also request that you order the sealant for ice maker thermostat=
Jan 09, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Water in door but none to ice maker-why
couple of things to check make sure there is no obstruction where the fill tube comes into the icemaker... if ice builds up in plastic tube it will not allow to come into ice maker... if there is ice there most likely the water valve is not closing all the way... these are normally dual water valves meaning one solenoid goes to ice dispenser /water dispenser and the other works the ice maker good luck
Dec 31, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker jammed. Ejector fingers in incorrect position.
Is the position off - or the icetray heater failed?
Just before ejection - there is a heater element that warms the ice for easy discharge.
Check that the heater is working.
Reply with the model # of the fridge for more exact help.
Thanks!!
Apr 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Jan 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
My ice maker is not dumping the ice it just freezes and stays in there help
You need to replace the ice maker . It is a lot less time consuming to replace the ice maker , than to try and repair it . But , if you want to try , you have a bad thermostat , or broken gear . If the gear type , pull the cover off the ice maker , and you will see the motor running ( small gear ) , but not turning the large gear . In this case , replacing the large gear , would be the best thing , instead of replacing the whole ice maker .
Nov 21, 2009 | Admiral Refrigerators
Ice maker is making ice but not dropping into bin. i can dump in myself and it re fills water, but the cubes just stay in the maker and wont alow the next batch to be made.
Your trouble can be in the icemaker. An internal thermostat closes to begin the ice harvest cycle. A motor drives the ejector blades, and a heater releases the cubes from the mold. None of this will happen if the electronic sender and receiver are faulty. This device is to stop the ice production when the bin is full. How are you manually dumping ise into the bin?
Nov 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
Defrosted and now it won't make ice again
If the compressor or fan isnt running. Check your ejector blade in your icemaker.It should be at 12 oclock. If it isnt then remove the cover of the icemaker and turn the smaller gear counter clockwise until the ejector blade gets to the 12 oclock position. This should start the unit.
May 10, 2009 | U-Line Icemaker
My ice maker isn't making ice
the way the ice maker sits in the front of the freezer I personally think is not a good design.nice but not good.most every k.a. superba that had problem with icemaker that i have checked had a bad ice maker.replace the icemaker.but you may want to check all tubing connections from water valve to icemaker and make sure no break in line.most likely it is the ice maker.that ice maker is not a cheep one.good luck.
Mar 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
60 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
